Old 14-11-12, 09:52 PM   #11
Default Re: Valve grinding on an sv650?
I'd run it and see what happens, if it has good compression and makes good power... be reet.
I'd assemble it with valve clearances to top end of clearance and check again after 10 hours or so of running and probably again after 600 mile.
Ordinarily they would be renewed if the valves were disturbed - but they don't play any part in the valve sealing.
The valve stem seals keep the oil in the cam box and not puffing out of the exhaust.
Doesn't he know it
Sv650 injected Pair Valve Solnoid removal kit £22 sv650k4 For Sale - SV's and SV related items 3 12-06-12 06:27 PM
Grinding when first starting out al88 SV Talk, Tuning & Tweaking 4 17-06-11 05:44 AM
sv650 shims and valve clearances tommy-d SV Talk, Tuning & Tweaking 1 28-07-09 06:57 AM
Grinding 1st!! Spider SV Talk, Tuning & Tweaking 9 02-01-07 02:50 PM
SV650 Valve Clearances - how easy to adjust? bsam20 SV Talk, Tuning & Tweaking 13 09-11-04 08:52 AM
