Old 22-04-07, 08:18 PM   #1
Grinch
Default SV650 N choke and throttle cables.
Right, need them to convert my SV650S so that the renthals fit. Anyone got any, else I'll just pick up some new ones.
Old 23-04-07, 08:33 AM   #2
Jase22
Default Re: SV650 N choke and throttle cables.
You shouldn't need either of those. Bit of re-routing required, but there was easily enough length when I did my swap.
Old 23-04-07, 09:59 AM   #3
Grinch
Seemed a little tight to me... I'll have another go and yank it all out.
Old 23-04-07, 12:06 PM   #4
Jase22
Just seen your other post, seems you're using different risers, which appear higher than the standard N ones. The cables look a lot tighter than mine are, so perhaps take what I said with a pinch of salt.
Old 23-04-07, 12:07 PM   #5
Grinch
Ah salt, yes... I'll give another go though, as if I can save a few bob I will. But then I'm a tight ar53, as Scoobs will tell you.
Clutch cables/Throttle cables Curvy 21QUEST For Sale - SV's and SV related items 0 05-08-08 08:45 AM
Throttle, choke and clutch cables for an 's' Stig Stuff Wanted 1 15-01-08 01:56 AM
Someone cut my throttle cables! SVeeedy Gonzales Bikes - Talk & Issues 42 29-03-07 12:16 PM
Throttle Cables ugp Stuff Wanted 7 30-12-06 12:15 PM
Throttle/Choke/Clutch cables. Grinch Stuff Wanted 0 08-03-06 01:14 PM
