Old 08-11-18, 01:35 PM   #1
zombie
zombie's Avatar
Default Fixing a jacket collar?
I have a textile jacket where the Velcro collar is too tight and doesn't stick together. I "extended it" with an extra bit of Velcro but it doesn't hold.
Is there something that can be stuck on as a replacement? Both parts of a press stud, or another Velcro type thing?
Something requiring no sewing....
It seems like this should exist!
zombie is offline   Reply With Quote
Old 08-11-18, 02:45 PM   #2
zombie
zombie's Avatar
Default Re: Fixing a jacket collar?
Thanks
Can't sew, but also it is ballistic nylon (Furygan) so pretty tough!
I thought about that popper (with tool) but still need something to stick a bit of material to the other side (ie it needs to extend as well as fix together).
Old 08-11-18, 03:13 PM   #3
zombie
zombie's Avatar
that's an idea. I have one. How to stick to jacket though?
Old 08-11-18, 03:40 PM   #4
zombie
zombie's Avatar
"However: in my modelling (aircraft not body),"
Ha Ha
Ok, thanks.
Old 08-11-18, 08:01 PM   #5
Kambo
Junior Member
Try your local dry cleaners, some do alterations
Kill two birds with one stone
Kambo is offline   Reply With Quote
Old 11-11-18, 07:12 AM   #6
andy650
I've had success with gluing velcro with copydex glue. Both to its worn out opposite, and to leather.
Apply glue, hold together with a clamp overnight.
Not sure of your exact situation, but maybe Copydex and double sided velcro will help?
andy650 is offline   Reply With Quote
Old 11-11-18, 12:30 PM   #7
make a velcro extender.
its very very easy and no sewing required. but 1/2mtr (of hook and loop parts) of the same size or slightly larger adhesive velcro as on your jacket collar. cut the velcro parts to the required length. stick the two velcro parts together to form a hook side and a loop side so its one piece of fabric. attach extender to velcro on collar between the original velcro on your collar...
Old 11-11-18, 02:06 PM   #8
SV650rules
https://www.livingmadeeasy.org.uk/dl...otwear-2680-p/
Other types available as shoe fastening extenders or similar.
2016 SV650 AL7
Old 12-11-18, 08:43 AM   #9
Kambo
Junior Member
Those press studs/clothes rivets (second reply) are your best bet, just like the pop buttons you get on textile jackets
Easy to do
Old 15-11-18, 03:48 PM   #10
zombie
zombie's Avatar
The jacket had a spare press stud (it has them on the sleeves).
I couldn't work out how to do it properly, and didn't have the tool, but I made holes in the collar and stuck one on each side utilising a hammer and superglue. Works fine so far.
Broken collar bones DomP Idle Banter 11 03-12-17 12:57 AM
Testing bark control collar... Brettus Idle Banter 9 15-12-14 12:33 PM
Cracked Fuel Cap Collar mase_tw Bikes - Talk & Issues 2 05-07-13 09:02 AM
Exhaust Collar DANINPLYMOUTH Stuff Wanted 4 30-10-09 07:56 PM
poll: How's your collar bone? Bear Idle Banter 29 10-09-07 12:26 PM
