Old 14-04-12, 02:15 PM   #1
AZZ3R
Default Failed MOT
My 02' SV just failed its MOT because of the front brake light is not illuminating the rear light.
I've changed the levers from OEM to short levers.
Unsure what the problem could be? Not making a complete circuit once the lever is pulled in? Or if the wiring has had it?
Rear brake lights it up fine passed on everything else but the problem above.
Anyone else had this problem or know how to solve it?
Old 14-04-12, 02:20 PM   #2
Dicky Ticker
Default Re: Failed MOT
Similar problem on changing with the contacts on both clutch and brake before.Long time ago but I think it only needed a little spacer on the switches
Old 14-04-12, 03:02 PM   #3
Yep, had the same problem
Switch was buggerd. Easy job, part number 5. It'll have fallen apart inside
Wemoto or Robinsons for a new one
Part# 57460-17C01
Old 14-04-12, 03:25 PM   #4
Might well be the switch, but, before spending money that may not fix the problem:
Originally Posted by Me!
take the wires off of the front switch and join them, does the brake light come on?
If yes then the switch is the problem, remove it, fill with WD40 or similar and operate the switch with your finger a few million times. If the switch still 'clicks' then it very likely hasn't mechanically failed, so the 'switch full of WD and click it a lot' approach often works in cleaning the contacts.
Old 14-04-12, 06:16 PM   #5
Do as Sid says, but when you take the switch off, give it a little shake, if it rattles its fubarred, no amount of WD will cure it.
Old 14-04-12, 09:00 PM   #6
suzukigt380paul
had a similar problem on the b12 with none oe levers and had to put a plastic wire tye round lever with a spot of silicone as the lever did not push the button on micro switch in far enough to put brake lever on
MOT Failed :( AJDBaillie Bikes - Talk & Issues 43 17-03-12 09:04 PM
MOT Failed! Dunn-y Bikes - Talk & Issues 16 18-05-11 12:49 PM
failed again shiver85 Bikes - Talk & Issues 5 17-05-08 12:04 PM
TRE mod failed on 07 vegacr250 SV Talk, Tuning & Tweaking 21 09-07-07 10:28 PM
MOT failed Grinch SV Talk, Tuning & Tweaking 8 26-06-06 06:32 PM
