Old 14-06-14, 11:36 PM   #1
Aligowers
Default How many litres of coolant? Curvy.
Hi guys about to order some coolant of ebay for my sv650 curvy 02 . Cant find the amount I need in the haynes. Only website I could find a number was in quarts worked out about 1.933 litres. Should i buy three just to be safe.
Old 15-06-14, 12:33 AM   #2
Dave-the-rave
Dave-the-rave's Avatar
Default Re: How many litres of coolant.
1.6 liters.
SV650N K1
Dave-the-rave is offline   Reply With Quote
Old 15-06-14, 12:34 AM   #3
Aligowers
Cheers buddy will order some just now.
Old 15-06-14, 09:11 AM   #4
You'll need distilled water if its not pre-mix (most isn't).
Old 15-06-14, 07:20 PM   #5
Teejayexc
Teejayexc's Avatar
Why do you need distilled water
Teejayexc is offline   Reply With Quote
Old 15-06-14, 08:29 PM   #6
Nutsinatin
Nutsinatin's Avatar
You know what the inside of your kettle looks like with all that limescale? You don't want all of that inside your rad and cooling system, can cause blockages.
Blue K9 Pointy - Squished by a car/kerb/wall
Blue K9 Pointy #2 - Nearly at 120,000 miles!
Nutsinatin is offline   Reply With Quote
Old 15-06-14, 08:31 PM   #7
this.
Lost a litre of clean coolant as I ended up washing scale out with it
Old 15-06-14, 08:41 PM   #8
Teejayexc
Teejayexc's Avatar
The antifreeze additive does the corrosion/prevention controlling, ordinary tap water to get the correct mixture ratio will be fine.
Old 15-06-14, 09:32 PM   #9
jambo
jambo's Avatar
I'd say it depends on the water in your area. In a soft water area I'd happily use tap water. Where I am the water is actually something like 90% limestone with just enough water to let it move through the pipes so I buy distilled or premixed.
Jambo
Sent without a real keyboard
Old 16-06-14, 03:39 AM   #10
Aligowers
Default Re: How many litres of coolant? Curvy.
Luckily up here in Scotland the waters great we don't get limescale at all. I bought pre mixed coolant. Ill run the hose pipe through it to clean out the coolant system. Then take all the old fluid to the recycling dump. Got about 10lt of oil to get rid of as well.
Crash.NET - Penalty for 'eager' Laverty, uses all 24 litres NewsBot News 0 24-03-14 12:10 PM
Crash.NET - Nicky Hayden 'limited' to 22 litres NewsBot News 0 22-03-14 02:10 PM
How many litres of luggage space for a week away? Miles Bikes - Talk & Issues 26 01-06-09 07:19 PM
17.5 litres my ****! schofs Bikes - Talk & Issues 14 25-11-08 03:22 PM
