Old 12-02-15, 09:21 AM   #1
bobbleheadbarne
Default Chain and sprockets
Hello all
need help I'm looking at getting new chain as I spotted little patch of rust and it's stretched I have 4 notches left in the rear swing arm.. my question is what type is best and I will also do new sprockets any tips please thanks all for your help
Old 12-02-15, 11:26 AM   #2
clydeflouride
Default Re: Chain and sprockets
Should replace sprockets at same time definitely. When I do mine I'm going to go one tooth down on front sprocket for acceleration.
Old 12-02-15, 11:30 AM   #3
bobbleheadbarne
Ok cheers for the speedy reply mate so if I follow on and go a tooth down will this affect speedo and what chain you going for please
Old 12-02-15, 11:50 AM   #4
clydeflouride
I dont believe it affects the speedo, as it's seperate from how the SV measures its speed. Think it measures rotations of the front wheel or something?
I've read Tsubaki chain and Renthal sprockets is a good combo. But I'm someone wiser will come along, I'm curious to hear some opinions myself!
Little bit of reading here: http://www.2wheeltuesday.com/2009/10...tsubaki-chain/
Old 13-02-15, 12:15 PM   #5
Jayneflakes
Jayneflakes's Avatar
Which model of SV do you have? My pointy measures speed with a spinning magnetic field on the wheel, so was not affected by a sprocket change.
When I changed my chain, I used a DID chain and sprocket set from a e-Bay, the whole lot cost about £150 at the time, but I did go for the best I could afford.
Top tip though, a chain oiler maintains your chain and allows for greater distances between changes. I use a Tutoro Auto which is a simple and and elegant design, but other types are available.
Jayne you're a Pussy Magnet
Old 13-02-15, 11:39 PM   #6
barryreynolds
I've gone for a 520 - 15/46 sprockets with a renthal rr4 chain. Not to hard to fit but need a tool
Cost with tool in total was about £220
Old 18-02-15, 07:11 PM   #7
bobbleheadbarne
I have 2004 sv 1000.. I have a shot oiler but my chain has rust on it
Old 18-02-15, 07:12 PM   #8
bobbleheadbarne
Scott oiler lol not shot
Old 18-02-15, 08:28 PM   #9
How bads the rust?
Old 18-02-15, 10:00 PM   #10
bobbleheadbarne
Surface really but I feel rust is rust I'm I in correctly saying this
New chain & sprockets - where from? Telford_Tim SV Talk, Tuning & Tweaking 1 13-05-11 06:54 AM
Chain and Sprockets adoh30 Bikes - Talk & Issues 3 17-08-08 02:37 PM
New chain and sprockets dmracing SV Talk, Tuning & Tweaking 3 01-05-07 03:50 PM
Chain & Sprockets Again. SpankyHam SV Talk, Tuning & Tweaking 10 09-08-06 11:26 AM
Chain and Sprockets??? Chimpy SV Talk, Tuning & Tweaking 6 18-03-06 10:22 PM
