Old 22-01-09, 10:57 AM   #1
drag
Default Rejetting and Rebuilding carbs . help
It's gotten to the stage where i badly need to rejet my stock set up carbs.
Currently on my 01 i have a K and N air filter, and a CCC can, the results of which are a huge flat spot at 4K rpm in second gear, and general lumpiness down low, and between gears.
What i aim to do is, Remove the carbs and clean them, following this thread http://forum.svrider.com/showthread.php?t=85513
Once thats completed, i'll fit Tank spacers and remove the foam from under the tank, and rejet.
I have been half thinking about fitting a BMC RS filter also, but cash is a bit tight and will have to wait
My main questions would be as follows.
  • Based on the set up described, ( CCC can, K and N filter, tank spacers and removed foam ) who wants to guess the jet sizes i should aim for ? cash is a bit low, remember we are in a recession over here also in Ireland.
  • What about cleaning my carbs, would ethinol be usefull in this process or would i be better off take then some where and get them blashted ( not the technical term of course)
Old 22-01-09, 11:02 AM   #2
Dappa D
Default Re: Rejetting and Rebuilding carbs . help
wouldnt wanna guess as im pretty useless..hower i will say with my viper end can, standard system, bmc rs race filter, defoamed and raised i was using 155 mikunis and it was spot on...it may have been better with slightly larger or smaller ones but i started at 155 and was happy enough not to go through all that again lol
Old 22-01-09, 11:04 AM   #3
drag
Had a good read over your thread DD, it was pretty good help in getting ready to do this, it's just a bit of a pain in choosing the right sizes.
Lets see what the pro's have to say ....
Old 22-01-09, 11:09 AM   #4
Isn't there a proper way to work out what size you need? I think my tzr needs new jets, its pouring fuel out the exhausts
Old 22-01-09, 11:12 AM   #5
drag
You know im no expert, but that really cant be good right ..
Old 22-01-09, 11:31 AM   #6
Nope. It's because it has race jets. I don't think it will get through emissions in the mot
Old 22-01-09, 11:32 AM   #7
Dappa D
i know of a way of testing them based on throttle position/speed/revs etc...however this is a long process....rejet...test...rejet...test....rejet... .test....
well....
when i say i know of a way...what i mean is i have the testing information in a file somewhere im sure......would it help if i can find it and mail it to you?
Old 22-01-09, 12:43 PM   #8
drag
well....
Already have that PDF matey, think you actually mailed it to me, get her in 4th gear at 6.5K rpm and see if she pulls and then let the trottle back to 7/8 position ...all that stuff
Cant be terribly hard to test, just need a general idea of sizes to order i guess
Old 22-01-09, 05:14 PM   #9
Flat spot at 4k, try raise the needles a clip setting before forking out £6 for jets. Mains kick in more like 6k though there is some cross-over.
Do not use ethanol except where you are certain no rubber or plastic parts remain. Degunk the float bowls with carb cleaner if you wish, however the safe bet is to use petrol and compressed air.
Quick test, whack it wide open at 6krpm and see if it stumbles.
No such thing. And what is a race jet when it's away?
Old 22-01-09, 05:16 PM   #10
Dangerous Dave
+ 1
As Dappa said, 155's maybe the ones to go for.
Rebuilding the SV fighter. Grinch SV Talk, Tuning & Tweaking 34 27-08-09 05:44 PM
Rebuilding calipers? irl_dar SV Talk, Tuning & Tweaking 54 06-03-09 10:33 PM
Rebuilding '03, Need: forks, radiator, headlamp Broncstang Stuff Wanted 0 13-11-07 03:23 AM
rebuilding SVS, do I have a choice of motor? dizzzzz SV Talk, Tuning & Tweaking 1 14-01-07 02:38 PM
Cleaning up the carbs/rejetting Saracen SV Talk, Tuning & Tweaking 12 06-03-06 12:53 PM
