Old 10-12-10, 09:54 PM   #1
TamSV
TamSV's Avatar
Default Difference between 99-02 & K3 CCT?
I have bought from fleabay what was advertised as a K3 cam chain tensioner to replace a dodgy standard curvy version.
It looks identical in every respect to the old one. How can I tell the difference? I thought there was a spring in the top of the K3 CCT but that might have been a dream.
I'm not too fussed, just curious. It works, so it's going in. The garage door's been frozen shut for a week so I'm going to take advantage of the thaw.
Old 10-12-10, 10:27 PM   #2
hardhat_harry
Default Re: Difference between 99-02 & K3 CCT?
You needed a K5 if you wanted to get the upgraded CCT
Old 10-12-10, 10:41 PM   #3
TamSV
TamSV's Avatar
Then that's been one vivid dream I had
I was sure the K3 was the upgrade for a curvy and the new design for k5 onwards wouldn't go.
Old 10-12-10, 10:53 PM   #4
hardhat_harry
My K1 has K5 CCTs fitted, fixed my rattly engine.
Instead of just being spring loaded they have a rachet so they wont move back if the spring looses tension
Old 10-12-10, 11:00 PM   #5
TamSV
TamSV's Avatar
Yeah, that's what I was after.
Oh well, "working" is still an upgrade from "not working".
Old 11-12-10, 02:40 PM   #6
mjc
There were 2 updates to the tensioner-
X-K2 are the dodgy ones.
K3 & K4 have the same shaped sealing surface as X-K2 but have the ratchet type internals.
K5 onwards have a different shaped base. Can't comment on how well they fit cos I havent done it.
K3 should look totally different, sounds to me like you have been mis-sold carb model ones.
Big difference in HP? KillaSV SV Talk, Tuning & Tweaking 5 06-04-08 07:36 PM
An SV with a difference.... Daimo Bikes - Talk & Issues 30 05-03-08 10:34 AM
What a difference... Biker_Billy SV Talk, Tuning & Tweaking 25 23-02-08 11:01 AM
Age difference Frank Idle Banter 54 31-12-07 08:48 PM
The difference between an R6 and the SV... Ibanez7779 SV Talk, Tuning & Tweaking 37 23-10-04 01:59 PM
