Old 17-08-07, 05:43 PM   #1
rob13
Default Help working out a wage
Could someone work out for me how much is needed to be earned to come out with £1200 a month after tax with no other deductions than those which we have no choice but to pay?
Old 17-08-07, 05:47 PM   #2
neio79
Default Re: Help working out a wage
about 20K
Old 17-08-07, 05:47 PM   #3
El Saxo
20k per annum = £1282.43 pcm after tax & NI
EDIT £1244.93 if you are repaying a student loan as well.
HTH
Old 17-08-07, 05:50 PM   #4
Jabba
Depends on your tax code and you might be receiving other "benefits", e.g. phone, company car, mileage allowance, etc.
Sounds like "about £19k" given the examples above, but this might be a bit more accurate if you want to take your personal circumstances into account.
HTH
Old 17-08-07, 05:53 PM   #5
El Saxo
Agreed, it would differ depending on tax code etc.
I used this to get the figures above based on my circumstances (hence why I mentioned Student Loans).
Looks the same as the site Jabba found but you don't have to know your tax code.
HTH
Old 17-08-07, 06:14 PM   #6
rob13
thanks lads, my question is answered
Old 12-11-17, 03:07 PM   #7
EvieG2017
Smile Re: Help working out a wage
Hi rob13
I had do a similar calculation myself recently as I needed the same amount per month to cover the costs of rent etc. Got offered a few different jobs but in the end had to go with the one that offered at least £16,350.
At £16,350 per year you'll end up with a take home wage of £1,200 each month. If you need to work it yourself or find yourself in a similar situation I'd use this:
http://www.income-tax.co.uk/calculator/16350
Hope that's helped, I had to try and survive on that wage in London, it certainly wasn't easy! Hopefully you're not living in London?!
Old 12-11-17, 03:42 PM   #8
Chris_SVS
Chris_SVS's Avatar
This thread is over 10 years old
Chris_SVS is offline   Reply With Quote
Old 12-11-17, 03:45 PM   #9
EvieG2017
Ahhh, didn't even realise?! still hoping it's still useful even 10 years later
Old 13-11-17, 06:47 PM   #10
DJ123
DJ123's Avatar
https://listentotaxman.com/
BMW F800ST
Key not working wilky007 SV Talk, Tuning & Tweaking 12 29-12-08 01:27 PM
Speedo working, then not, then working??? krhall SV Talk, Tuning & Tweaking 25 24-04-08 11:35 AM
Wage slaves, what T&A do your employer use? timwilky Idle Banter 10 20-10-07 08:13 AM
not working Again! wtdafk SV Talk, Tuning & Tweaking 18 10-01-07 05:29 PM
Working on the SV william t. SV Talk, Tuning & Tweaking 12 04-09-06 10:23 PM
