Old 22-11-07, 09:32 PM   #1
harvy
Default Early First Service?
The dealer i got my k6 from did the first service early as part of the purchase.
(Bike was ex demo and had 336 miles on the clock).
This week i hit 600, should i bother gettin another "first service" or will it be fine till the next ones due? ( thats 1 year or 4000 miles if i remember right?)
CBR 125.... sold!
SV650sport k6
R & G's, scottoiler and heated grips... ie not a lot changed!
harvy is offline   Reply With Quote
Old 22-11-07, 09:35 PM   #2
Default Re: Early First Service?
Change the oil and check over for loose bolts and stuff, won't hurt it.
Old 22-11-07, 10:13 PM   #3
on yer bike
I agree with him above ^^^^
Old 22-11-07, 10:18 PM   #4
tomjones2
+2, if you havent done it before changing the oil is easy.
Old 23-11-07, 07:54 AM   #5
harvy
done oil changes in a car plenty of times, just not on a bike yet!
quick qs, what grade oil do i need to put in? im guessing car oil is a no no?
CBR 125.... sold!
SV650sport k6
Old 23-11-07, 08:14 AM   #6
gettin2dizzy
It's a bit ****ing no no. Car oil has additives in to reduce friction - your bikes clutch sits in this oil so it would just slip all over the place. I find there's normally only one grade of bike oil for sale in bike shops anyway. Easy, the one with the bike on it.
Old 23-11-07, 11:29 AM   #7
SV650Racer
Totally no need to change the oil yet unless you can afford to. Oil will last alot longer than 300miles!
Bolt check it all over though. Routine checks really that every bike owner should do every few weeks really.
Old 23-11-07, 01:49 PM   #8
tomjones2
I thought the reason for changing the oil was that there is a chance that the engine isn't fully run in yet, having only completed half its standard run in period?
Old 23-11-07, 02:13 PM   #9
Car oil vs bike oil. Again.
I think it works, have proven it doesn't cause clutch slip, some people with access to the tribology lab at my uni have proven it holds viscosity just as well. Blah blah
but I still would say use bike oil for peace of mind and warranty.
The idea of changing oil after the running in period is because this first bit of the engines life produces a lot of fine particulate (more than at any other time) and the oil filter won't catch this fine stuff.
Either way an oil change won't hurt, and its only about a tenner.
Old 23-11-07, 03:36 PM   #10
SV650Racer
The run in period!. Ok mainly the aim of this period is to bed the bike in. Allow components to settle down effectively without any tech jargon here!.
The bike will actually bed in better if you stick to the schedule and use it!. Changing the oil now wont make any difference at all as its already been done. The first service is actually 600miles or 2mths whichever is sooner. So it isnt strictly mileage critical.
Just ensure you get the engine warmed up properly before riding, dont labour the engine at low revs in a high gear either. You need the rings to seal to the bore properly so just warm it up and ride.
Enjoy!
can i get an early rad to fit a K5 650 tonny006 SV Talk, Tuning & Tweaking 2 07-08-08 11:12 AM
Why am I up so early? Drew Carey Idle Banter 6 08-03-08 08:59 AM
Thought I'd get in there early..... Vickster South & West Surfers 11 02-01-08 09:32 AM
Service Manual for SV650S 2001 and Service Recommendation stone SV Talk, Tuning & Tweaking 1 09-05-07 04:20 PM
Santa came early diamond Bikes - Talk & Issues 75 20-12-06 09:04 PM
