Old 25-11-07, 12:24 AM   #1
metalmonkey
Default Anyone know what this is?
http://cgi.ebay.co.uk/sv-650-extra-b...QQcmdZViewItem
Saw it on ebay, but don't see how it could make that differnce I know it has been said, want more power get a bigger bike!
Just wonderd what its is claiming to be, but it does like like LOB to me!
Old 25-11-07, 12:29 AM   #2
ThEGr33k
Default Re: Anyone know what this is?
HA HA ace, check this out http://forums.sv650.org/showthread.php?t=100771 Its pretty much the same thing, and guess what, we posted within minutes...
Old 25-11-07, 02:46 AM   #3
maultin
does it work?
Old 25-11-07, 04:39 AM   #4
rictus01
rictus01's Avatar
The general consensus seems to be "no better than the home mod" which is easy enough (do a search/ look on the home page under how to's).
The carbed version was also a marginal call as well (and they were £100 at one time).
TRE mod links
Curvy
Pointy
Cheers Mark.
Old 25-11-07, 04:41 AM   #5
kcowgergmm
i believe its just a timing retard eliminator if so i thought it was worth wile but i wouldn't pay that much
Old 25-11-07, 04:14 PM   #6
ThEGr33k
Do you people actually notice a change in feel/performance?
Im guessing it just makes it fire earlier/later?
Old 25-11-07, 06:16 PM   #7
Apparently the timing is later in 2nd and 3rd gear to comply with noise regs, or in the case of TLS and cagiva raptor thou engines to soften the power a little.
TRE mod apparently sets the timing back to optimum level (more advance in 2nd and 3rd, ie fires earlier, further before TDC)
This gives a little more power.
I say apparently because I've never put a timing light to one to find out.
Old 25-11-07, 06:21 PM   #8
ThEGr33k
Hmmm, surly then the resistor addition would mean that the 4,5 and 6th gears would be firing even before optimum because itll move as well?
Man i wish there was a manual of how to and effect of tuning!
Old 25-11-07, 06:24 PM   #9
No, the different gears don't need more advance.
Suzuki just gives them different advance due to legislation.
TRE makes the bike run in the 6th gear map, which is optimised for good power on fairly naff fuel.
(you can advance it more, but this requires higher octane rating to prevent pinking)
Old 25-11-07, 06:48 PM   #10
ThEGr33k
I didnt mean the gears needed it, i was meaning adding a TRE or a resistor to do the job would surly cause all the gears to get advanced ignition not a select few. (The mod rictus linked above).
