Old 25-11-07, 06:02 PM   #1
Blue_SV650S
Default Name that whel in 1!!
No prizes for spotting it is a Kawasaki wheel It's a mechanical 'worm gear' speedo drive, so can't be anything too modern?
This isn't a competition as I don't know the answer, just hoping someone in SV land recognises it. I can make a guess, but I wanna know for sure ... the wheel code Enkei F-1301 will hopefully give the game away to someone?? ... I tried a bit of goggle-fu, but to no avail!
Old 25-11-07, 07:12 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Name that whel in 1!!
look at http://www.bikez.com/pictures/large....iel Salter.jpg
gpz500, the rear has the same look
Old 25-11-07, 07:27 PM   #3
Blue_SV650S
Na, it is not a GPZ wheel, this takes two discs for a start (GPZ only has 1)
Old 25-11-07, 07:35 PM   #4
orose
it also has a BT010 wrapped around it - my mates baby GPZ has a 110 section tyre, which is only available in their BT45 "classic" range. Could be one of the early 6s though - early ZX6R or ZZR perhaps?
Old 25-11-07, 07:40 PM   #5
hovis
Peter?
Old 25-11-07, 07:55 PM   #6
Blue_SV650S
I think it is an early E model ZZR (not as early as a D model, but the first few rounds of the E model say 92-95?) ... but not sure ... like I said, whoever has a Kwack with a similar looking wheel can check the number stamp and all should become clear?!?!
If it helps the disks off it are 298mm in diameter and slightly offset (i.e. in the same sort of way the curvy SV discs are offset) ...
Anyone got a ZZR600??
See my thinking:- http://alain.rouge.free.fr/6/0411zzr600.jpeg
Old 25-11-07, 08:05 PM   #7
...this takes two discs for a start (GPZ only has 1)
You're right about early ones, but don't later GPZ500s have two?
... ZZR ...
That'd be be my guess.
Old 25-11-07, 10:09 PM   #8
Lozzo
There is a GPZ500 E model that has twin discs. It was around in Europe long before the UK got twin disc models in 2001. A couple of years ago I had a 1996 P regd GPZ500 winter hack that had twin discs as standard - it was a parallel import from Italy.
That wheel looks like it may well have come from a ZZR as the discs on a GPZ don't fit that close to the centre
Old 25-11-07, 10:12 PM   #9
Biker Biggles
Biker Biggles's Avatar
Can it really be as old as 92-95?
If its a Kawasaki wheel it would have rotted away by now.
Old 25-11-07, 11:03 PM   #10
tinpants
Ubique
tinpants's Avatar
If it was a Suzuki wheel it would have rotted away by now.
Can't say fairer than that.
Jesus loves you. Everyone else thinks you're a pillock
tinpants is offline   Reply With Quote
