Old 27-11-07, 12:14 PM   #1
Jase22
Default Curvey engine
Ideally local(ish) to me so I can come collect it. Needs to be a runner so it can be pretty much swapped for current engine and ridden.
Don't intend to spend a fortune, but let me know what you got as I'll stretch the budget if it's a good 'un.
Jase
Old 27-11-07, 11:04 PM   #2
r4ce_e3nd
Default Re: Curvey engine
I have one but I live in Belgium
Old 28-11-07, 08:09 PM   #3
Jase22
Tempting as that one of yours has all fancy cam action doesn't it? It'll cost a mint for sending though wouldn't it? Gutted.
Old 29-11-07, 04:45 PM   #4
r4ce_e3nd
I've replaced the cams so I can't sell them.
Don't know how much to send the engine to you. If you still want it I can look it up for you. How much does an engine weigh??
Old 29-11-07, 05:00 PM   #5
Jase22
Yeah if you don't mind that'd be helpful. As for the weight, I know not. Guessing it's a fair amount though.
Dry weight of bike is 165kg for reference. Now if you just deduct the weight of all the other parts, there you have it ha ha
Old 30-11-07, 12:07 AM   #6
Richie
fantabulas
Richie's Avatar
Your looking at 30-40 Kgs... if the price is of the engine is right (cheap enough) then maybe the postage will be covered...
Shop around for a good priced courier.
My Flickr photos
Old 01-12-07, 12:21 PM   #7
Razor
Just drive to Zeebrugge and pay somebody to put the engine in the boot of their car before they get on the ferry. Jase waits at Hull and collects engine, easy
Just don't give in to the temptation of packing the engine with illicit pharmaceuticals.
Old 01-12-07, 03:18 PM   #8
r4ce_e3nd
This is a possibbillittyy (too many characters, I know)!
But the question is, how much is the engine worth? It has more or less 70k km's. A small leak at the front cylinder (you can see it looses a wee bit of oil, but I don't know where it's comming from, not a big concerne me thinks) and I know that the coolingwaterpump has leaked once, but since then not anymore (with a new seal this most be fixed). There are no problems with the gearbox at all, the clutch still works properly and it doesn't slip. It has seen a few trackdays, but always warmed the engine enough befor kicking the gas.
Ah yes, it consumes a wee bit of oil (don't know exact how much) but I think this is normale for the km's it has...
Always had it's oil and filter refreshed on time. The valve clearence should be ok, but you must check befor running it (didn't check it when I replaced the cams, because I didn't have the time to).
That should be it!
What do you think?
Old 11-12-07, 07:15 PM   #9
Jase22
Will drop ya a pm.
Old 11-12-07, 07:43 PM   #10
r4ce_e3nd
Found it!
Cheap Curvey Engine HopefullySoon Stuff Wanted 2 21-04-09 10:25 PM
Engine for a curvey drag Stuff Wanted 0 12-08-08 10:14 AM
breaking curvey engine shifter For Sale - SV's and SV related items 0 15-06-08 03:22 PM
WTD Curvey Engine twonk Stuff Wanted 9 16-05-07 10:10 PM
