Old 06-12-07, 03:12 PM   #1
TheStudent
Default Curvy Lower Fairing & R&G Crash Bungs
Fitted my lower fairing the other day for the first time and i already had the bungs on, i noticed on the right side the fairing is literally touching (potentially light pressure) one bung and on the other side there is about a 1mm gap, is this correct? I didn't have any instructions when fitting the fairing because i bought it off eBay, could the brackets be alligned incorrectly or...?
Thanks folks, any help much appreciated!
Old 08-12-07, 07:55 PM   #2
TheStudent
Default Re: Curvy Lower Fairing & R&G Crash Bungs
Does no-one own a curvy with lowers and bungs?
Old 08-12-07, 08:08 PM   #3
Paws
You need to slightly trim the fairing to make them fit 100% iirc.
Old 08-12-07, 09:01 PM   #4
BristolMatt
I've a curvy, R&Gs and lower farings and it's the same as you - the side are not quite identical. The bungs are on there as they should be and unless you know about it or look hard, it doesn't show.
Old 09-12-07, 11:46 AM   #5
WelshWop
Mine is the same. Hasnt been a problem though. The fairing isnt marked or damaged in any way.
Old 09-12-07, 02:56 PM   #6
Mine were like that too... I could sort of shift the fairing forward slightly to get the same clearance but then it had odd panel gaps so I just left it. It shouldn't be a problem, if you have an off the bung will bend in the opposite direction so it won't break the fairing. Certainly wouldn't cut the fairing, that'd kind of defeat the purpose.
R&G crash bungs and lower fairings intruder86 SV Talk, Tuning & Tweaking 0 08-06-08 05:00 PM
Crash bungs on lower fairings Ward8124 Bikes - Talk & Issues 11 19-02-07 06:32 PM
2006 Suzuki Lower Fairing w/ Frame Sliders (crash bungs) Maestro Bodywork 1 29-11-06 08:35 AM
Crash Bungs With Fairing Lowers, Curvy: MrMessy SV Talk, Tuning & Tweaking 7 04-07-06 03:56 PM
K5 Pointy Lower Fairing & Crash Bungs ridelikaking SV Talk, Tuning & Tweaking 8 31-03-06 07:44 AM
