Old 07-12-07, 08:48 PM   #1
sv_rider1990
Exclamation Pyramid Undertray?!
Right im thinking about fitting a Pyramid undertry or powerbronze undertray havent yet decided but i have my alarm fitted to the stock undertray and i was thinking would i be able to cut the tool tray and the other bits off the stock bit thats of any use and glue gun it to the new colour coded one? I know it sounds bit stupid but all my alarms wired up their and cant be ars3d to re wire it and all that shizzle lol? If any of you have any other ideas please feel free!
Thanks alot!
Old 07-12-07, 09:28 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
Default Re: Pyramid Undertray?!
Most of the original undertray is kept if you fit a pyramid undrtray just need to cut off the back bit so your tool tray bit will be unaffected
2011 Speed Triple 1050
Old 07-12-07, 10:32 PM   #3
Dangerous Dave
The Pyramid one is of better quality, and can come colour matched. As dirty dog said most of the original undertray is kept, you simply saw off the the top end. The only problem you might have is the alarm mounting bolts. Check the underside of the standard undertray for signs of 1 or 2 bolts coming out that secure the alarm in place, these will get in the way. Best thing to do if you have this problem is undo the mounting bolts and secure the alarm back down with heavy duty double sided foam tape.
Old 07-12-07, 10:40 PM   #4
sv_rider1990
My Alarms a meta that i fitted myself and thats fine i guewss as long as the majoritys kept. So i wudnt need to move my alarm whatsoever with the pyramid?
Old 08-12-07, 09:46 AM   #5
Rich
Rich's Avatar
Have a look at this write up i did a while ago, alot of people found it useful. I fitted the pyramid one it was a snip as you'll see
http://forums.sv650.org/showthread.php?t=80152
Rich
RIP Hovis - Unlucky Boyo
Old 08-12-07, 10:01 AM   #6
sv_rider1990
Alright thanks alot hopefully will be a piece of p1ss then
pyramid undertray jimmy SV Talk, Tuning & Tweaking 6 02-06-10 12:57 PM
pyramid undertray Warren SV Talk, Tuning & Tweaking 2 03-10-06 09:40 PM
Pyramid Undertray/ Tail Tidy Curvy :SOLD: SpankyHam For Sale - SV's and SV related items 6 02-10-06 06:49 PM
Pyramid Undertray UlsterSV SV Talk, Tuning & Tweaking 4 06-03-06 09:36 AM
Pyramid Plastics Jacques SV Talk, Tuning & Tweaking 9 12-12-05 06:35 PM
