Old 08-12-07, 05:22 PM   #1
mbuk
Default Starting problems
Hi everyone - newbie here and hoping that someone can confirm my thinking.
I've had my SV650S K2 for 2 months now. Unfortunately I broke my ankle (not on the bike!!, but stupidly rode back to Cardiff from Leicester before getting it checked out) last week so can't ride, drive or generally do anything!
I went out to give the bike a start today and hit some problems.
Initially it started with half choke and ran ok but a little rough, it settled and kept going with the choke off, but as soon as any throttle was applied it stalled.
Now it won't start with or without choke. After having a scan through here and some other sites I came across the fuel filler / water problem.
On opening the filler sure enough there is a lovely pool of water which poored straight into the tank
So my guess is this has probably happened before and fuel is contaminated and probably some blocks some where. So I'm guessing it will need a strip down and drain as per the "water in fuel" doc and then try and sort out the drain hose.
Does everyone think the same? or am I missing something?
On a separate note the bike is going to be stood for the next 5 weeks - any advice on things to do to try and make that as painless as possible for it!
Cheers for any help
Mike
Old 08-12-07, 07:32 PM   #2
Red ones
Red ones's Avatar
Default Re: Starting problems
Several things to do.
Lift the tank and reroute the drain tube from the tank - on the K2 they had a tendency to run the tube the wrong side of the frame - causing it to kink and not work - run it the other side (search the main site for the solution). http://www.sv650.org/sv_faq.htm#Are%...filler%20caps?
then add Wynns dry fuel to the tank and run it through
should do the job
I would also check the underside of the tank for rust - not uncommon and at £325 tanks are not cheap!
Old 11-12-07, 06:23 PM   #3
mbuk
Great thanks!
Old 12-12-07, 11:02 AM   #4
Spanner Man
Morning all.
If an excess of water has got into the carburettors you'll need to drain them. For this task you'll need a 5mm ball ended allen key. The drain screw for the front carburettor is a sod to access, a small torch helps here.
I would drain the tank too, & mop out any water still remaining.
Cheers.
Spanner Man
Starting problems with my Sv 650 K3 -pATz- SV Talk, Tuning & Tweaking 5 30-03-06 08:30 PM
Problems starting riktherider SV Talk, Tuning & Tweaking 4 11-06-05 06:13 PM
Starting problems squirrel_hunter SV Talk, Tuning & Tweaking 2 14-05-05 09:37 PM
starting problems JakeRS SV Talk, Tuning & Tweaking 4 02-05-05 01:04 PM
Starting problems... Aaron SV Talk, Tuning & Tweaking 9 22-12-04 07:45 PM
