Old 09-12-07, 07:02 PM   #1
maultin
Default front footrests/gear & brake spiggets
hi guys,
can anyone tell me where to get new front footrests & brake/gear spiggets?
the ones on the SV are original & 12k miles worn
I would like to get metal footrests (like already on back) and metal spiggets.
cheers
Alan
Old 10-12-07, 10:25 AM   #2
John Burt
Default Re: front footrests/gear & brake spiggets
Spiggets??
Old 10-12-07, 11:33 AM   #3
maultin
spiggets - possibly a local term, sorry.
the bits that stick out at the end of the rear brake & gear change lever - the bits with the rubber on them
Alan
Old 10-12-07, 12:39 PM   #4
YZEtc
Suzuki dealers in the US can order replacement rubber pieces for the tip of the gear shift pedal, so I wouldn't be surprised if it's the same for you.
I don't think the brake pedal uses a rubber tip, but is bare serrated metal.
If the tip of that pedal is shot, I'd just replace the pedal and have it done with.
The rubber covers on the footrests aren't available as separate pieces on US parts catalogues.
What I'm going to do for my K7 (now that it's tucked away until the road salt vanishes) is replace the original footrests with all-metal serrated (my preference) ones from a late model GSX-R - do some cross-referencing in catalogues that sell aftermarket sportbike footrests and you'll probably be able to tell which bikes' footrests will fit.
Old 10-12-07, 12:54 PM   #5
maultin
cheers for your comments YZEtc
Old 10-12-07, 01:07 PM   #6
ejohnh
wemoto(online) do the non oem parts much cheaper.
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front and rear l/h footrests etc hog Stuff Wanted 1 26-05-07 07:03 AM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
