Old 10-12-07, 08:05 PM   #1
phil24_7
Default GSX-R Front end questions. (New I think!)
As some of you may know, I'm in the process of fitting a GSX-R front end to my K3 SV. It's been going quite smoothly and has been alot easier than I ever imagined apart from a few small problems.
First was fitting the clutch lever on to the TLs clip-ons. It wouldn't fit on far enough to allow the switch gear to be mounted but this was sorted with a grinder and some paint! Second was the GSX-R brake line wasn't long enough to attatch to the the master cylinder but a careful bit of manipulation managed to get it sorted until I can get some braided lines.
Now for the problems that I haven't solved yet!!
1. For those who have the GSX-R shock fitted, where did you mount it to as I can't see anywhere for it to mount to the bike.
2. Has anyone experienced the bottom yoke rubbing/catching on the inside of the lower fairing? If so had did you deal with this, did you trim the fairing, space the fairing out or use a different fix?
Cheers for any advice
Old 10-12-07, 09:24 PM   #2
Default Re: GSX-R Front end questions. (New I think!)
Do you mean the steering damper?
PICS!
Old 10-12-07, 10:18 PM   #3
phil24_7
Yeah, sorry, not paying attention. First question was about the steering damper.
Sorry, no pics today as I forgot to take the camera up to the workshop! Will post some tomorrow but wouldn't mind some suggestions for tomorrow so's I can try to get it working like it sposed to!
Old 10-12-07, 10:59 PM   #4
Lozzo
Does it need a steering damper? I'd have thought with a Gixer front end in it would be even calmer than usual.
Personally, I'd leave the damper off until I'd ridden the bike and then decided if it was needed. I wouldn't fit the stock Suzuki one either, the one on my Gixer Thou made it feel like I was steering the bike through treacle, but still allowed the odd slapper. That was sorted by fitting an Ohlins unit in a 916 stylee.
Old 10-12-07, 11:19 PM   #5
SVRAsh used the OE damper, i think he might have used lighter oil. Like Lozzo, I wouldn't. Didn't!
I've never heard of this fouling issue, and I would have thought I would have. Curious... Home badly does it foul?
Old 10-12-07, 11:32 PM   #6
phil24_7
So you recon it's worth pm'ing SVRash to see where he mounted it? Not 100% that I'll fit it, just want the option!
It's only about 3-4mm on the near side and about 1cm on the off side and it's only the lower of the lower clamps bolts that catches!
If it isn't common or hasn't happened to anything else then something must be up with my sv, either damaged/misaligned fairing brackets or bent frame or something. Either that or I've royally f**ked up the front end conversion!!
Old 11-12-07, 01:02 AM   #7
Never heard of that before, but that doesn't mean that much in this cast to be quite honest... What yokes did you use?
Old 11-12-07, 02:10 AM   #8
phil24_7
Used the K5 yokes that were with the forks. Gonna check everything tomorrow to make sure I haven't screwed up.
Old 11-12-07, 12:18 PM   #9
Dangerous Dave
Check that your fairing sits straight on the bike first, then have a look at the yokes and forks.
Old 11-12-07, 02:43 PM   #10
phil24_7
Fairing apperas fine as everything lines up with holes and other panels! Gonna double check everything now and update this evening.
Front brakes report and questions! Camel SV Talk, Tuning & Tweaking 10 24-04-08 08:51 AM
front end change -same old questions gruff SV Talk, Tuning & Tweaking 1 09-09-07 06:34 PM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
a few questions....well 5 questions....from a newb flynn209 SV Talk, Tuning & Tweaking 12 10-07-06 10:56 PM
Finally got the front spark out, couple of questions. Saracen SV Talk, Tuning & Tweaking 3 27-02-06 10:34 AM
