Old 11-12-07, 01:46 PM   #1
Grant66
Grant66's Avatar
Default Fork adjusters
Hi,
Whilst the bike is off road I thought I'd do the front fork oil change. The guide (on here) suggests making it stiffer using washers, but I've noticed a few adds around t' interweb for adjustable fork tops.
Do these do the same job? Are they recomended?
Grant66 is offline   Reply With Quote
Old 11-12-07, 01:50 PM   #2
Default Re: Fork adjusters
You can't make the front end stiffer with washers, that adjusts preload not spring rate, but apart from that yes, the two do the same thing. I'm not sure if I'd say recommended, I used mine for 10 minutes then never adjusted them again but it saved me a fair amount of trial and error doing it with spacers.
Old 11-12-07, 03:40 PM   #3
Blue_SV650S
Indeed, once the correct 'sag/preload' is set, there will be little need to change it again ... so having the luxury of an adjuster is probably a little superfluous after initial setup!!
Looks cool though
Old 11-12-07, 03:41 PM   #4
Grant66
Grant66's Avatar
Ah, preload not stiffer.
More noob questions comming
How do you know when its right?
Feels better or is there some sort of checks/calculations dependant on body weight.
Am I right in thinking heavier=more preload?
Old 11-12-07, 03:57 PM   #5
Blue_SV650S
Have a proper read of sag/preload ... its a good page and tells you ballpark figures and exactly how to test.
Basically if you want real ballpark, IIRC it works out you want the bike to have used ~1/3 if the available front travel (distance from fully extended/unloaded to just under the bottom yoke) when you are sat on the bike in the riding position and wearing all your gear!! You keep winding the preload up (put more washers in) until this is the case.
How much do you weigh in at??? Id say if you were >14st then you need to seriously think about getting new springs …
Old 12-12-07, 12:14 PM   #6
Grant66
Grant66's Avatar
Just over the 14st mark at present & with Christmas coming up its only going to get worse
What springs should I be looking at?
Old 12-12-07, 12:28 PM   #7
Viney
Bouncy ones
HTH
Old 12-12-07, 02:30 PM   #8
Luckypants
Luckypants's Avatar
got to racetech.com and use their spring rate calculator to get the spring rated for your weight. Also remember to factor in weight of gear.
In my case I wanted pre-load adjusters as I did 50/50 with/without pillion. Fit fork oil to suit the springs.
Old 12-12-07, 02:41 PM   #9
Alpinestarhero
Try heavier fork oil and see how you go with that.
BTW, nice topbox
Matt
Old 12-12-07, 03:27 PM   #10
Blue_SV650S
got to racetech.com.
Indeed
Without even looking, my guess is the 85 springs for you my friend*
* I might have some 85 springs for sale as it happens
What do i need to convert the 1999 (no preload adjusters) to having preload adjusters and progressive springs. sv_rider1990 SV Talk, Tuning & Tweaking 12 11-07-08 05:15 PM
preload adjusters. scottjames SV Talk, Tuning & Tweaking 16 28-04-08 04:06 PM
Fork preload adjusters on a curvy? Berlin SV Talk, Tuning & Tweaking 12 06-09-07 08:00 AM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
FORK PRE-LOAD ADJUSTERS ON A 'NAKED' alexb SV Talk, Tuning & Tweaking 4 21-01-05 09:19 PM
