Old 16-12-07, 12:34 PM   #1
John 675
Default Air intake question
im just up for my 12.000 mile service, and part of it is renewing the airfilter.. question is,
ive purchased a K&N air filter, after all sorts of chinese whispers and false info.
will i see a noticeable differance in performance or the way the bike runs? im not HP counting at all i ask because i hate getting new bits.. the bike feeling different and me thinking something is wrong lol,
any info?
Old 16-12-07, 02:36 PM   #2
Default Re: Air intake question
Depends how it flows, if it's freer flowing than stock then it may end up running lean, which isn't good.
Old 16-12-07, 03:24 PM   #3
orose
It depends which one you got as well - there are two that fit some of the pointy SVs.
One is a straight replacement for the standard one, but made out of battery farmed K&N pixies (so it lasts for ever). The other is made out of free-range pixies, so the airflow is a bit higher and that can make it run lean as Chris mentioned, especially if its freer at the other end.
I had a quick gander over at K&Ns site (www.knfilters.co.uk) and they don't appear to do the latter one for the 2005 bike (they do for the 06, as I had to check myself). Like you, I'm not in the chase for HP either, but I haven't noticed any difference between before and after.
The other thing to watch out for is to make sure you stick the little K&N sticker on the airbox lid (before they open it), and mention that you've done the air filter when it goes in for the service, if you're not going to get them to do it for you - would be a shame if they chucked a filter thats supposed to last a million miles after less than a hundred.
Old 07-01-08, 09:45 PM   #4
j1m1jarv1s3xper1ence
Cool Re: Air intake question
Hiya , How can you tell if the bike is running Lean?
I have a 2003 SV650s and have installed K&N air filter. The first day out on I found that it kept cutting out if the revs were too low then it sorted itself out but Im still a little worried. Is this a sign of it running lean?
Old 07-01-08, 10:40 PM   #5
What K&n? There is one type that is the same as the standard just reusable.
Lean makes it hesitate when you open the throttle. Among other things
Old 07-01-08, 11:17 PM   #6
YZEtc
There are two different K&N air filters available?
Old 07-01-08, 11:59 PM   #7
$tevo
It's interesting to me (was ignorant of the fact til I looked) that the same air filter is quoted for the SV1000 too. Given that, I wouldn't have thought that it would give a 650 any air restriction problems at all.
Also, I could only find one filter on my search - SU-6503
Old 08-01-08, 12:04 AM   #8
Isn't there a road and a race one?
Or am I mixing myself up with BMC ones on the curvy....
Old 08-01-08, 12:15 AM   #9
YZEtc
BMC does have two version for the 1999-2002 models, the street version and race version.
I've been told the race version flows more air with the trade-off being more dirt flowed, as well.
The size of the air filter element or even the size of the airbox on the Pointy SV-650s doesn't look restrictive to me, but the size of the puny air inlet snorkel does.
I'd imagine that freeing this up to allow more air (and fuel after proper adjustments are made via a Power Commander) in will get you a corresponding increase in intake noise.
Old 08-01-08, 12:20 AM   #10
Or TEKA/ yoshi box for a sight cheaper.
Hole in intake rubber? cammy SV Talk, Tuning & Tweaking 19 16-04-09 10:11 PM
Curvey intake valves and some collets svrash Stuff Wanted 2 30-01-07 09:48 PM
intake cams SV650 K3> r4ce_e3nd Stuff Wanted 3 29-05-06 10:08 PM
Curvy intake cams, engine barrels northwind For Sale - SV's and SV related items 0 17-01-06 02:19 PM
Air Intake! InvisableGeek SV Talk, Tuning & Tweaking 25 31-03-05 06:35 PM
