View Poll Results: which would you go for?
20" 3 37.50%
20" widescreen 5 62.50%
Voters: 8. You may not vote on this poll
Old 28-12-07, 11:24 AM   #1
hovis
Default monitor........ which one?
http://www.argos.co.uk/static/Browse...1500006485.htm
EDIT it should read 20" widescreen
Old 28-12-07, 11:46 AM   #2
Luckypants
Luckypants's Avatar
Default Re: monitor........ which one?
You don't say what you use your PC for. If watching movies, then the widescreen format would be better. For eveything else the good old square format is a better option.
I presume you are upgrading your current monitor which is smaller? Will your graphics card support a sufficient number of pixels at good enough colour depth to make full use of a larger screen?
Old 28-12-07, 11:50 AM   #3
hovis
You don't say what you use your PC for. If watching movies, then the widescreen format would be better. For eveything else the good old square format is a better option.?
dunno? i just want to replace the old CRT bulk, just surfing, i dont watch films, or play gmes
i dont think i have a grafix card?
Old 28-12-07, 11:53 AM   #4
orose
As they're both the same price and manufacturer, I'd go with the first one (black display)
You get a higher overall resolution (and LCDs tend not to work very well outside of their optimum), the same brightness, as near as makes no difference identical dot pitch, but a slightly lower contrast.
The only downside I can see is that both are analogue input only, so if your PC doesn't have the blue d-shaped VGA connectors, neither are compatible.
Old 28-12-07, 11:57 AM   #5
Sudoxe
I use a pair of 19inch windscreen's on my desktop at home. It works well for me, my work laptop is also wide screen.
At work I use a pair of 18inch traditional shaped ones.
Overall I prefere the widescreen's, but im not your average user. I have unix shells and all sorts open and not just web browers.
Once you get use to them, there fantastic for surfing the web, having applications open side by side, etc. It depends on what you use a computer for I guess.
Dan
Old 28-12-07, 11:58 AM   #6
Sudoxe
2 quid and a DVI-VGA connector will fix that
Old 28-12-07, 12:04 PM   #7
Luckypants
Luckypants's Avatar
In that case go for the square one. You will get slightly more screen height with that, seeing as both are 20" and screen size is measured diagonally.
You will have screen driving hardware, if not a separate graphics card, then 'on board' graphics. The same still applies, will the graphics support a higher resolution to make the most of your new screen? You may find that your graphics will only support widescreen formats at higher resolutions, so check that first before you buy. To check, got to Control Panel ---> Display ----> Settings and adjust the screen area to see what higher settings are available.
Old 28-12-07, 12:20 PM   #8
hovis
whats that then?
Old 28-12-07, 12:21 PM   #9
hovis
whats that then?
edit.
http://en.wikipedia.org/wiki/VGA_connector
got one of these
Old 28-12-07, 12:29 PM   #10
Viney
Dan
*coughs*geek
17" CRT Monitor metalmonkey Idle Banter 0 05-02-09 11:11 PM
Is this TFT monitor anygood? metalmonkey Idle Banter 13 04-01-09 01:08 AM
I need a TFT monitor metalmonkey Idle Banter 2 24-04-08 03:20 PM
i got me a new monitor...... but hovis Idle Banter 27 25-01-08 05:40 PM
PC/monitor help hovis Idle Banter 9 04-11-07 08:54 AM
