Greg,
Hope this is of some help; Original Bar End Length - 28mm Width - 30mm Recess - 27mm (By recess i mean the part that goes against the handlebar, im just **** at describing things! ![]() Bolt - 90mm New Bar End Length - 40mm Width - 29mm Recess - 22mm Bolt - 65mm Pic showing the difference in length between bar ends and bolts; ![]() Difference in recess size; ![]() Standard bar end as it would be fitted to bike(washer & sleeve included) ![]() New bar end as it would be fitted to bike(washer & sleeve included). As you can see, the bolt doesnt come out of the other side.. ![]() Handlebar measurements; Rubber Washer(not shown in pic) - 20mm silver - 22mm black - 25mm Grip - N/A ![]() Pics arent the best as they were taken on my phone, but hopefully this is of some use..... if you want any other measurements or pics taken, gimme a shout. Any other pointy owners are welcome to compare sizes (Oooo er ![]() Last edited by Ollie_07; 30-12-07 at 10:57 AM. |
Thinking about it, If the standard bar end recess is 27mm and the new one is 22mm, it shouldnt really matter as the rubber washer/grommet is 20mm so fits within both of the bar ends anyway...
I think what is needed is just longer bolts, they would need to be the same size as the standard ones plus allowing for the additional length of the new bar ends, so they should be 102mm? Are they something that could be bought from B&Q and the like as i could try getting some to see if it sorts it? failing that i guess new ones would have to be made up... |
Hey Ollie,
Lots of info there, you must be bored lol. Think its a case of just longer bolts like you have summised. Let me know if you find some bolts at B+Q etc. Grannies birthday today, she's 80 bless, so I 'm off over there now. Bike playin second fiddle today. Good luck, Paul |
My new bar ends actually fit better than the standard ones because the recess is slightly deeper, meaning that they totally cover the rubber bung. With my standard bar ends you can see the rubber a little, which I never liked.
Ok so the measurements........ the standard bolt sticks out 69mm from the standard bar end the new bolt sticks out 33mm from the new bar end meaning the new bolt is 36mm short The new bolt's total length is 65mm so a replacement would have to be 101mm ![]() |
Are the bolts M6? Because if they are you can get a 100mm bolt here:
http://www.stagonset.co.uk/fasteners?cart_id=3246472_27172&prm_grp=A2_ScrewBo lt_SHCap_M6&summit=M6|Socket|Head|Cap|Screws#top |
Ollie,
You really took some time there, thanks. I understand now that maybe some pointy owners have just had a good match and maybe slightly smaller bars or they might have rubbed them down a little to fit. Can you tell me if you can use the bar ends and I can supply you with longer bolts? Or are they way too small (the recess) to rub down the bars or coax them in. I also understand now the difference between pointy and naked curvy's the rubber bung assembly is completely different. And the std bar ends are actually longer than mine. Also thanks for opening this thread. It makes more sense. Paul, I hope your gran had a great b'day ![]() Darren, Also thank you for the advice on bolt sizes and links to suppliers. I will supply the 100mm bolts though unless someone tells me otherwise. Cheers everyone have a fantastic New Year. Greg |
Can't say fairer than that!
Cheers Greg! |
#8 | |
Have you still got my address etc to send them too? Cheers, Ollie ![]() |
#9 |
#10 |
Hey Greg,
Received the longer bolts as you promissed today. Now fitted, looks great, cheers. Paul |
Pointy bar ends | stuartgallafant | Stuff Wanted | 4 | 17-05-09 08:49 PM |
Screws for Bar ends/ bar ends, black screen K3 Pointy | renman8957 | Stuff Wanted | 3 | 06-02-09 06:08 PM |
Hey Greg, dont lock posts just because you dont agree! | AlanSv | SV Talk, Tuning & Tweaking | 110 | 20-11-04 05:21 PM |
Test message for Greg | jumpy | Soho Massive | 5 | 22-09-04 06:44 PM |
