Old 31-12-07, 08:09 PM   #1
jon8oy
Default led rear lights
Hi can any1 assist me im looking for info on wiring in LED rear lights from a pointy with curvy wiring loom
cheers john
Old 01-01-08, 04:50 PM   #2
jon8oy
Default Re: led rear lights
nobody know??
Old 01-01-08, 05:14 PM   #3
Curvy has black/white as earth on the normal lights, white/black is brake light live and brown is the running lights(/sidelights whatever)...
So, just find which wires on your pointy lights have continuity to each other, presume they'll be a common earth. Then put 12v to various wires, it'll only work with the polarity one way so that'll show you which wire is which.
On a slightly different note, how the hell are you going to fit pointy lights to a curvy? Or are you using the whole rear end?
Old 01-01-08, 05:47 PM   #4
jon8oy
yep got it in 1 fitting the whole rear end, its gonna take a take a little fabrication but i sourced a full rear with clear back lights and integrated indicators.
finding that when i wired the indy's up they didnt work will it require a led box for voltage etc it has the proper suzuki connectors so i thought they would just work, the chap who sold it to me assured me they all work
Old 01-01-08, 10:30 PM   #5
SoulKiss
SoulKiss's Avatar
Just get rid of the curvy and get a pointy - job done - instant rear LEDs
Hope this helps
Old 01-01-08, 10:53 PM   #6
jon8oy
lol that wud just defeat the object of modding my bike and putting my own touch, dont get me wrong pointy's are ok and iv rode 1 but it just dont give me that hmphhh effect
Old 01-01-08, 11:09 PM   #7
-Ralph-
Is what you need in here?
www.sv650.org/sv_manuals.htm
Old 02-01-08, 11:54 AM   #8
LED's don't draw enough power to make the stock timer work, presume they flashed fast enough to cause epeleptic fits when you tried them?
It's been covered a lot before, you either need a motrax flasher relay, which is the better option, or a lot of ballast resistors, which is the daft option.
(you can junk the entire stock relay, bypass all the numpty switches, less to go wrong)
Old 02-01-08, 12:15 PM   #9
jon8oy
[quote=yorkie_chris;1376443]LED's don't draw enough power to make the stock timer work, presume they flashed fast enough to cause epeleptic fits when you tried them?
(you can junk the entire stock relay, bypass all the numpty switches, less to go wrong)[/quote]
would you know how?
Old 02-01-08, 12:19 PM   #10
Viney
Always wondered what that would look like and was going to do that one day.
The only issue with the clear lensed brake/indicator combo is that they use LEDS, and not Luxon leds like the std rear light on a pointy, thus being harder to see in the daytime.
after market rear sets / rear break lights etuna SV Talk, Tuning & Tweaking 2 16-02-09 09:38 PM
Rear LED lights on a curvy? Alpinestarhero SV Talk, Tuning & Tweaking 12 30-10-08 09:24 PM
K3 Point rear lights tomjones2 For Sale - SV's and SV related items 0 19-10-08 09:05 PM
Flashing Rear Lights blueto SV Talk, Tuning & Tweaking 24 21-02-08 08:25 PM
Transparent rear Lights agentsteph007 SV Talk, Tuning & Tweaking 4 17-10-04 03:53 PM
