Old 06-01-08, 12:26 PM   #1
Wideboy
Evel Knievel
Wideboy's Avatar
Default gutless
as title says really.
took the bike out this morning and it was absolutely gutless , i have no idea whats wrong with it. Pulling away is pants and the usual little flat-spot it gets in 1st has gone because it usually kicks in about mid range then i get good power afterwards, but now i don't.
i then thought it was because it needed a service BUT its not due for a service for another 100 miles so its not as though I've been neglecting it.
I last took it out on Monday and it was running perfect, roads weren't wet, all i did was put it in the garage and cover it over and it was bone dry.
im a bit of a numpty when it comes to twins as i've only had experience with singles and mopeds
im going to shoot off in min to get the stuff to give it a service.
05 DRZ400E
RIP hovis
Old 06-01-08, 12:57 PM   #2
sinbad
Default Re: gutless
How does it sound?
Old 06-01-08, 12:59 PM   #3
mattSV
mattSV's Avatar
Default Re: gutless
Did I pass you going through Botley?
Ah, just seen your PM
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 06-01-08, 01:00 PM   #4
YZEtc
Default Re: gutless
See if anything is blocking the air intake or even for a rodent's nest starting to accumulate inside the airbox.
It's possible.
I've read that 1st generation SV-650s use a stick-on sound dampener that's on the underside of the fuel tank, and if this falls away from the tank, it blocks the air intake directly below.
Old 06-01-08, 02:04 PM   #5
Wideboy
Evel Knievel
Wideboy's Avatar
Default Re: gutless
Originally Posted by sinbad View Post
How does it sound?
sounds normal thats why i was puzzled
It's possible.
thats what i was thinking. im about to delve into the bike and give it a bluddy good service
yes was me, i was in a hurry to get home
05 DRZ400E
RIP hovis
Old 06-01-08, 02:14 PM   #6
Biker Biggles
Biker Biggles's Avatar
Default Re: gutless
Sticking chokes/plungers?Always a favourite on the curvy.
Old 06-01-08, 04:05 PM   #7
Default Re: gutless
Possible sticky choke as mentioned, worth taking them out and cleaning and greasing them and the cables. But it's worth doing that often anyway. As well as removing the foam under the tank, because it does nothing and you might as well.
If that and the air filter are OK then I'd possibly check the carb diaphragms
Old 06-01-08, 05:11 PM   #8
HopefullySoon
Default Re: gutless
hi
I'm experiancng simialr probs
[derail]
If i cover the rear carb air intake the bike stalls , if I cover the front carb air intake the bike stills runs , am I right in thinking that the front carb hasn't got an airtight seal and is drawing air in elsewhere .
Sorry
[/derail]
Hopefully Soon
Last edited by HopefullySoon; 06-01-08 at 05:12 PM. Reason: Cos I can't spell my own nick
Old 06-01-08, 05:13 PM   #9
Default Re: gutless
Are they balanced?
If you've got the balancing screw wound way too far out and the idle adjuster unscrewed a fair way then that would allow it to do that, and also be really lumpy and horrible. If that all checks out then have a look for an air leak, if its not something stupid like the carb clip rusted in half then its possible the rubber boot has a hole in it, hairspray works to temporarily seal leaks like that, but it would have to be a big leak if putting your hand flat over the carb mouth doesn't stall it. You're not a million miles from me, give us a shout if you want me to take a look.
Old 06-01-08, 05:17 PM   #10
HopefullySoon
Default Re: gutless
If that was at me chris no idea , not got a carb balancer .
I noticed that the front slider wasnt fluttering as the back one was , and have hesitancy under acceleration and crap starting .
My sv650 is GUTLESS! bingnet SV Talk, Tuning & Tweaking 6 24-07-05 02:27 AM
