Old 10-01-08, 01:42 PM   #1
croddman
Default Misfiring/backfiring - any thoughts?
Hello all,
I wonder if anyone can view this and think what could be making my bike backfire
its had new clutch, new sparks etc
but its running very bad and backfiring a lot,
My freind thinks that the exhust has clappsted (sorry for spelling lol)
I took it down to my local garage before it got bad and they could not find a problem and as normal it did not play up down there
any views ??????
Thanks
Old 10-01-08, 01:44 PM   #2
Alpinestarhero
Default Re: Problem !
Had the carbs balanced recently? Has it got an aftermarket exhaust on it?
Backfiring could be due to the bike running rich...
Have you had the spark-plugs changed recently?
Matt
Old 10-01-08, 01:44 PM   #3
Well what does it smell like?
If it smells of fuel, then I'd start with the choke plungers, bit of a faff to do but not really that hard. If you do them then when you put them back fill the cable, splitter and spring recess with grease.
If it smells wierd then check for air leaks, it could also be seriously in need of balancing.
Could be backfiring due to air leak (lean) or due to stuck choke (rich) or badly out of balance (one running hot, other running rich), changing spark plugs will probably not cure this.
Old 10-01-08, 01:49 PM   #4
Scoobs
Have you been riding it in the wet? If so, my money is on wet front plug. Do a search. This is a really common problem, but really easy (if a little fiddly) to rectify.
Old 10-01-08, 01:52 PM   #5
croddman
I have had someone check the new plugs that I put in and there fine
it has a nasty smell coming from it when it gets warm / a mile down the road
then the backfiring comes in
Old 10-01-08, 01:55 PM   #6
What you mean check them?
What colour were they?
My money's on choke plunger, probably front one, and probably a right bugger to get out.
Old 10-01-08, 01:55 PM   #7
Alpinestarhero
What sort of smell? Burning oil smell? Petrol smell? That horrible smell that happens when rain water is falling onto a hot engine?
The water in spark plug idea seems like a thing, but then you would be complaining of lack of power?
Matt
Old 10-01-08, 01:57 PM   #8
Matt
Too right, a twin turning into a single is a very pronounced thing, also does it at random, not just when engine gets up to temp.
Old 10-01-08, 01:59 PM   #9
Scoobs
There's so much it could be, but without seeing the bike it is really difficult to diagnose. There are a few common issues with the curvies. Water in the front plug. HT leads break down. When they get hot they start arcing to the engine block rather than directing the spark to the spark plug. This would cause the bike to drop onto one cylinder and run pretty rough. Leads are pretty expensive though because the ignition coil is part of the lead.
Old 10-01-08, 02:05 PM   #10
I'm not sure about that one.
Misfiring update donscarecrow SV Talk, Tuning & Tweaking 0 05-09-08 06:45 PM
SV650S K5 Misfiring? Elky SV Talk, Tuning & Tweaking 9 13-05-08 08:05 AM
Misfiring even in the dry! thumper21 SV Talk, Tuning & Tweaking 9 04-03-07 06:14 PM
Odd misfiring problem drumwrecker SV Talk, Tuning & Tweaking 8 31-01-06 05:15 PM
Misfiring brolong22 SV Talk, Tuning & Tweaking 1 01-11-04 11:08 PM
