Hi all
Does any one know what socket fits the Diagnostic plug on the K5 svs and if I can get one fron RS or Mapplins with the spades? I want to make up a short lead with a switch, to be easily accesable under my pillion seat, so I can check fault codes when I'm out and about. I have a short bit of wire made up to check these, but when I'm out & running, it's a pain in the a*** to fit the wire into the plug. I have an intermitant fault that only occurs when I'm out See thread http://forums.sv650.org/showthread.php?t=102350 If this fault occurs again (with switch fitted) I could check what fault code was being displayed, then act upon it I would like to leave the plug 'as is' in case of a fault that has to go back to the dealer, so I think a little extension lead would work for me Any idea's? |
just tap in to wires behind plug and extend from there.
Speedo plug? | k146 | SV Talk, Tuning & Tweaking | 0 | 02-09-08 07:12 PM |
Just a plug for minimoto's | BILLY | Idle Banter | 0 | 01-04-07 09:58 PM |
Little plug in thing | GSXR Carlos | SV Talk, Tuning & Tweaking | 5 | 19-01-06 06:20 PM |
Wet Front Plug | fizzwheel | SV Talk, Tuning & Tweaking | 10 | 13-01-06 04:53 AM |
Charging problem, need diagnostic help!!! | Troy | SV Talk, Tuning & Tweaking | 12 | 20-09-04 11:21 AM |
