Old 12-01-08, 06:48 PM   #1
neio79
Default Flat spots in Rev range on ZX6R
Today while riding down and back to weymouth i noticed that my bike (2007 ZX6R)has a few flat spots on the revv range. Noticable at about 8K , 11K and 13K.
Bearing in mind it is still being run in and covered only 570 miles so far i know i should not be doing those revs. But when opening the throttle from closed to open or heavy acceleration causes noticable flat spots at said rev range , any ideas what can be causing it guys??
after and berfore those revs its fine and dandy and after about !)K generally it flies, got to 123 in 3rd today any help appriciated.
Old 12-01-08, 07:02 PM   #2
sv-robo
Default Re: Flat spots in Rev range on ZX6R
so why are you?.......naughty boy
Old 12-01-08, 07:18 PM   #3
neio79
cos its almost at the service point so thoughti would give it some moer beenz!! and its boring below 6K
Old 12-01-08, 07:27 PM   #4
Biker Biggles
Biker Biggles's Avatar
Get the first service done,then see if it still does it.If it does take it straight back to the dealer and get them to sort it.
Obviously dont mention it before as they will say you damaged it by not following the running in schedule.
Old 12-01-08, 07:35 PM   #5
neio79
yeah i will, not noticed it before this afternoon. I did not let the bike warm up before riding home ,and it was cold so could be that. HOpe its nothind serious. I will take it back if after the first service and on a warmish day its still doing it. Just semed to take ages to build speed in any gear from about 7.5-8.5K on windingthe throtle open all the way. I know that to get the best out of the 6 you have to keep it above 10K but even so it annoyd me at noticing it!!
Old 12-01-08, 08:27 PM   #6
ASM-Forever
Do you mean throttle lag/snatchy throttle...in that there is a bit of hesitancy if you suddenly crack the throttle open? Thats not uncommon and can be cured with a PC/remap if it bothers you.
SHould have got an R6. HTH.
Old 13-01-08, 12:12 AM   #7
Beenz
The allegedly most important reason for the rev limit on running in is to de burr/swarf the engine and bed in the moving bits. The oil change is very important before sustained warp drive. The odd rev out should not harm it though and arguabely does it some good. Try it after the service, I know someone else with a ZX6R the same model as yours and will ask him if its the same. It's about the same age as yours.
Old 13-01-08, 09:33 AM   #8
Frank
Hi mate,ok so its not a bike ,but my car felt flat across the entire range,Jumped in it yesterday for the first time since christmas and because the misses had clocked up a few miles ,I could really feel the diff.As said above,get the service out of the way and give it time to free up
Old 13-01-08, 12:59 PM   #9
neio79
Yeah please that would be great, thanks!!
I hope its just an other change the engine is going through , as only noticed it yesterday. To start with i did run in as per book ut to about 300 mile i was carefull, then i started opening her up a bit. I know there are a few schools of thought on the run in process as wellall reckon its better for the bike.
Also i have just looked on the power curves in an old copy of Fast bikes mag and at around the revs i am describing the power band dips off of flattes of for a bit before picking up again.
First service next week and ill see if that makes any differance. If when i get to the 1000 mile mark its still doing it i ll be back to the dealer to get them to take it out and see if they think there is a problem with it!
Old 13-01-08, 01:15 PM   #10
Toypop
I doubt you would get much joy from the dealer. Far better putting it on a dyno first so that you can go to the dealer armed with a piece of paper.
Chains - Tight spots Viney Bikes - Talk & Issues 18 26-07-08 10:04 PM
white spots on rad hoses madEG SV Talk, Tuning & Tweaking 15 13-07-07 08:39 PM
Rust spots on disks Dee4Life Bikes - Talk & Issues 11 03-01-07 12:58 PM
newbie spots red sv near waterloo emcf Soho Massive 6 07-12-06 10:42 AM
Green Spots Warlock Idle Banter 1 20-06-06 09:04 AM
