I am in the need to fabricate a bracket to support the clocks. I have no idea yet how I am going to achieve this task, I'll think about that when I have the material to be used.
Can anyone give me some suggestions on what to use ![]() I thought of using some sort of sheet metal. But it will need to be pliable enough to bend into the position that I need. It will also need to be strong enough not to bend out of the position I want it in. Lastly in needs to be strong so as not to get metal fatigue due to the vibration that will inevitably be caused. Idea's anyone ![]() |
I'm just revising for an engineering materials exam in the morning.
How convenient. ![]() I'd use sheet metal, anything will do really, but make sure it's supported to that the clocks don't have significant leverage advantage on the bracket, the leverage stresses on the outside of the part cause tiny fractures to grow as well as work hardening the part making it less resistant to snapping. If you can use sheet ally, and make the bracket a triangular shape so the parts are in pure tension and compression then that'll reduce the chance of fatigue failure.
Cheese?
Sheet ally, get it into shape then weld on a couple of supports to stop it moving.
I'd suggest 2 mm stainless. Or:
If you want to paint it then 2 mm mild steel. You'll need a bench vice to bend it neatly. I'd be inclined to go for the mild steel - tough enough and easy to work. A blowlamp for heating if you need any tricky bends. ![]() |
Oh Si, lend me you ally welding gear
![]() Right getting realistic just for a moment, whilst others may have funds to burn, I'm guessing you won't want to be doing this more than once and at the most cost effective. to that end, create a template,rough shape you want and showing the mounting holes, to do this get something like a metal biscuit tin lid (you should be able to cut it with snips (or a big pair of scissors, but don't tell Jo ![]() Once this is done, if you want the shiney look get some stainless, however mild steel will be cheaper and if you're painting it it'll be just as good, 4mm sheet will do nicely and if you bring the template and sheet to me I'll fabricate it for you. If on the other hand you want to do it yourself, then probably 2mm will do, but make sure you vector in either a central mounting point or one either side to fit a brace(s) to support it, given your access and tools, I'd drill and rivet it to the main bracket. Cheers Mark.
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, 'Wow! What a Ride! Last edited by rictus01; 15-01-08 at 10:08 AM. |
#9 | |
I shall have a looksee over extended weekend that I have coming up. I know exactly what you mean and will produce a template as soon as I can. The only issue that I have is where to mount a bracket from. For the naked yolk there were two handy threaded holes on the underside to mount from. On the faired yolk these are not there. Anyway I shall have a nose around and see what sort of creative mind I have. ![]() ![]() |
#10 |
If you have the time, money and the inclination. as a fabricator myself i agree with all of the above statement. 2mm ally should do the job just fine. if you want to get a beautiful design on the go, i would suggest using auto cad and then get the part machined out. should look pucka and fit like a dream. providing that you have all the correct dimentions. also opens up the options of using diffrent materials such as plastics.
TON2000 |
Replacement can bracket | Sigfreid | SV Talk, Tuning & Tweaking | 2 | 20-05-09 12:05 PM |
Headlamp bracket for a K3 | Lozzo | Stuff Wanted | 0 | 21-10-07 10:44 PM |
Exhaust Bracket - Help. | krhall | Bikes - Talk & Issues | 11 | 13-08-07 08:53 PM |
sidestand bracket... | dizzyblonde | Stuff Wanted | 1 | 11-07-07 12:43 PM |
Fairing bracket | copper kettle | SV Talk, Tuning & Tweaking | 0 | 15-06-06 12:38 PM |
