Old 24-01-08, 09:24 AM   #1
Paul the 6th
Paul the 6th's Avatar
Default S k3 rear hugger - will it fit an S k5?
found a rear hugger on fleabay in the states, it's listed as SV650 2003 03 HUGGER BLUE - will it fit my k5 (only reason I ask is because many bolt on accessories are usually listed as 2003 onwards ('98-02' and '03+'). thanks in advance pt6
Old 24-01-08, 09:34 AM   #2
SoulKiss
SoulKiss's Avatar
Default Re: S k3 rear hugger - will it fit an S k5?
No it wont.
The K3 is not compatible with anything but K3's
The K3 has a higher seat height, and after many people complained, they redesigned the back of the SV, making the K4 onwards lower.
To do this they moved the battery down a bit and due to lack of space under the seat, put the toolkit holder under the battery.
This means where there is nothing between the wheel and the shock on a K3, the battery box fouls the K3 hugger when put on a K4.
It will probably fit, but 1st big bump will crack it
Old 24-01-08, 09:38 AM   #3
Paul the 6th
nice one cheers buddy - I need to read up on the changes made each year so I don't have to report back here everytime I find somethin on ebay lol...
also, v quickly, I'm assuming k3 screens should fit all 03 onwards SV's then? Since the rear end changes shouldn't really affect the screen/front end mountings etc?
thanks again
No it wont.
Old 25-01-08, 11:30 PM   #4
phil24_7
Screen is the same.
Old 26-01-08, 05:28 PM   #5
Lozzo
It will physically fit the swingarm, but you have to chop the whole of the toolbox off the bottom of the battery box to give the hugger clearance. I did this with my K5 because I was too pikey to buy a new hugger and liked the shape of my old K3 one. I never used the toolbox thing anyway and it looked ugly.
And yes, it is painted satin black and looks gorgeous.
Old 27-01-08, 06:19 PM   #6
blingking
I fitted a k3 model hugger to my k4 with a bit of fiddling. The tool box has touched but to be honest it has not damaged it. The suspension is standard and i weigh 13 stone and its ok
black rear hugger or carbon rear hugger? chipnix SV Talk, Tuning & Tweaking 9 05-07-07 04:05 PM
Rear hugger! dowdy01 Stuff Wanted 0 19-04-07 06:58 AM
Rear Hugger krhall Bikes - Talk & Issues 19 01-03-07 03:55 PM
Rear Hugger krhall Bikes - Talk & Issues 9 28-01-07 11:25 AM
rear hugger for k3 james160987 Stuff Wanted 0 11-01-07 09:58 PM
