Old 29-01-08, 12:58 PM   #1
ikb
Default Carb balancing by ear?
Is it OK to balance curvey carbs by ear? Just like the old twin SU's on Minis etc?
Coz I have just done mine with a bit of tube in my ear and it runs far better now!!! I do have many years tuning Trials bikes and cars, but i'm not a professional!
And while i'm here my 2000 curvey has fork springs that are about 430mm long! So are they :-
An after market goodie
or just out of something else
As Im new to road bikes they seem fine to me!!
Old 29-01-08, 12:59 PM   #2
flymo
flymo's Avatar
Default Re: Carb balancing by ear?
cant see any harm in that, but obviously it would be more accurate with a set of gauges. Unless you have the ears of a bat
Old 29-01-08, 01:00 PM   #3
One pot will run a bit hotter if they're out, but if it feels better then it's probably an improvement.
You can make a vaccuum gauge with some clear tubing and oil/coloured water if you haven't the money for proper gauges.
Old 29-01-08, 08:15 PM   #4
I got mine pretty close... But you'll never know for sure without gauges.
Old 29-01-08, 08:28 PM   #5
toonyank
Welcome to the show
You'll get all the advice you need on balancing here.
As for the fork springs, my trust manual says fork spring free length is:
Standard 314.6mm
Service limit 308mm
So like you said they are either after market or from another bike.
Greg
Old 29-01-08, 10:35 PM   #6
ikb
The main reason for doing the balancing by ear is speed, airbox off and adjusted in 10 mins!
But I did make the mistake of reading the manual first as it said remove every thing to get to the vac ports!
Old 29-01-08, 10:36 PM   #7
I reckon I can do it with gauges in about the same.
Just have a bit of hose from the front pot blocked off somewhere convenient.
Old 29-01-08, 10:36 PM   #8
Yeah, that's a ridiculous way to go about it- just add a tail onto the front port, and you can balance the carbs in minutes in future. I did it by popping the carbs off, took no time at all to set up.
Old 30-01-08, 12:25 PM   #9
johnnyrod
johnnyrod's Avatar
I must have fingers like the guy in Total Recall, I can just about get the tube onto the front stub, though it is tricky and you can get burned. If I gave a monkey's i might fit the extension. Gauges all the way though.
Old 30-01-08, 01:20 PM   #10
ejohnh
Hey, you guys with the gauges, how much vacuum or head(in metres?) does the carb/engine produce when it is idling?.
Carb balancing Grinch Soho Massive 10 07-05-09 07:44 AM
Carb balancing. scottjames SV Talk, Tuning & Tweaking 12 27-10-08 01:14 PM
carb balancing ricky SELKENT 6 22-04-08 08:11 AM
carb balancing Banus SV Talk, Tuning & Tweaking 9 23-02-06 01:38 PM
carb balancing johndo SV Talk, Tuning & Tweaking 3 08-04-05 05:31 PM
