Old 04-02-08, 08:18 PM   #1
joronsen
Default clutch and throttle cable
Hello, I have a cagiva raptor 650ie, it is the same engine that the sv, I have changed the handlebar and i need a clutch cable and throttle cable more long, does someone know all that measures that of a sv? That of the raptor measures 78 cm aprox. the clutch and 55 cm the throttle cable. Thank you very much.sorry for my english,i´m spanish
Old 04-02-08, 08:20 PM   #2
Biker_Billy
Default Re: clutch and throttle cable
Don't worry about your English mate - its a lot better than my Spanish!!
Can't help with the question I'm afraid, but hopefully someone will who knows a bit more about them...
Good Luck,
Billy.
Old 04-02-08, 08:42 PM   #3
Red Herring
Red Herring's Avatar
Hi there, yes I can help with the sizes from a K5 SV S model (drop bars) as I took them all off today in order to get longer ones for a straight bar conversion.
The clutch cable is 108cm long.
The twin throttle cables are 77cm long.
I hoping the cables off the naked SV are longer but my local Suzuki dealer didn't have any in stock to check. At £33 for all three I've ordered them in so fingers crossed.
Old 14-02-08, 09:08 AM   #4
Red Herring
Just to update on this the clutch cable was an inch or so longer and did the job perfectly. The throttle cables were slightly longer but have different size twistgrip connections, so if you want to use them you need the throttle tube off the naked as well. I've rerouted the old ones down the front of the tank with a certain degree of success.
Throttle return cable? Stevetmanchester Stuff Wanted 0 20-10-08 10:27 PM
Throttle Cable sticks joff80 SV Talk, Tuning & Tweaking 3 20-09-08 10:49 AM
k5 throttle cable help??? ben650 SV Talk, Tuning & Tweaking 2 21-01-08 11:40 PM
Throttle Cable M65 SV Talk, Tuning & Tweaking 5 23-06-05 08:48 AM
Clutch and throttle stiff to use - cable oilers??? huge SV Talk, Tuning & Tweaking 13 23-05-05 09:51 PM
