Old 06-02-08, 09:41 AM   #1
Grinch
Default Leaky Rad
My Rad is leaking, I've chucked in some rRdweld after a full coolant swap and the leak appears to have slowed. So I'm going to chuck some more in as I only used about a quarter as the Radweld as it said it will do 11 litre rad, so I thought it was a bit of a over-kill on my little 1.6 litre rad.
But mainly I'm looking for other ideas, as I can see the leak and I will try to get a photo sorted if you wish.
Old 06-02-08, 09:43 AM   #2
Grinch
Default Re: Leaky Rad
Ok no photos for now, work is rather 'over' locked down...
Old 06-02-08, 09:59 AM   #3
jambo
jambo's Avatar
Replace is easier than repair in most circumstances.
I've used this breaker search with some luck in the past:
http://www.bike-breakers.info/
Failing that there's a radiator shop / workshop of some kind at the end of Rictus' road, or there certainly used to be. No idea if they'd be happy sorting it?
Jambo
Old 06-02-08, 10:12 AM   #4
Grinch
How about I stick some chewing gum on it... lol.
Old 06-02-08, 10:17 AM   #5
Ceri JC
Radiators are radiators- a normal radiator repair shop will almost certainly be able to fix it (assuming it's repairable), don't go to a specialist bike/automative place to have it done, it'll cost a lot more. Obviously it'll depend on what needs doing, but I'd imagine it'll be cheaper than buying one from a breakers.
Old 06-02-08, 10:37 AM   #6
ELR4ever
I have a rad welded up before too, it broke at teh bolt attach points from stress. I had all the bolt points welded up and no probs now. Very cheap, just repaint it after.
Old 06-02-08, 11:35 AM   #7
Scoobs
Grinch,
I got a repair done in Hilsea - Limberline Spur. Back street place and it cost £15. Serck Marston wanted £180 for a brass recore or £300 for an ally recore.
Old 06-02-08, 11:44 AM   #8
Blue_SV650S
JB weld?
Old 06-02-08, 12:14 PM   #9
Grinch
Originally Posted by Scoobs View Post
Grinch,
Ah, it wasn't on this bike was it?
JB weld?
Pardon?
Old 06-02-08, 12:31 PM   #10
Scoobs
If you mean my old bike - YES.
Lasted at least 3 years so that ain't bad for 15 squids is it?
Leaky Pipes Demonz Idle Banter 6 29-12-07 12:17 PM
leaky petrol tap hovis Bikes - Talk & Issues 9 10-09-07 04:18 PM
Leaky Umbrella The Basket Idle Banter 6 18-05-06 03:16 PM
leaky garage roof anyone? kwak zzr Photos 18 22-04-06 07:45 PM
leaky can curium SV Talk, Tuning & Tweaking 3 06-03-05 05:32 PM
