Old 07-02-08, 01:59 PM   #1
21QUEST
21QUEST's Avatar
Default Ally Rear brake caliper torque arm ...from GIXER SRAD
IIRC , it's a straight bolt on to replaces therustimatic one on the SV650Northy is the man to ask on that so hopefully , he'll see this . Ooh, you get added lightness to boot .
Got Six to go. All in good condition. One or two might have a nick or two but all in good condition. £16 delivered.
Ben
Nemo me impune lacessit.
Old 07-02-08, 03:37 PM   #2
drag
Default Re: Ally Rear brake caliper torque arm ...from GIXER SRAD
Stupid question will they fit a 01 model and is it an easy and straight fwd switch ?
Old 07-02-08, 04:43 PM   #3
you have a PM, been looking for one of them
Old 07-02-08, 04:58 PM   #4
Weirdo. Yeah, it's a pretty easy swap, to be honest I can't remember exactly what was involved, whether it needed a hole enlargened slightly or not, but I do know it only took minutes to fit whatever.
Old 07-02-08, 05:17 PM   #5
GMS
GMS's Avatar
Mine needs painting again so I`l take one of those if thats ok Ben
Graham
Old 07-02-08, 05:23 PM   #6
andyb
The hole on one end needs enlarging very slightly. Apart from that a straight 5 min swap.
Old 07-02-08, 07:01 PM   #7
drag
Cool i'll take one then paypal i assume.
Old 07-02-08, 10:31 PM   #8
BILLY
Your like a magpie aren't you attracted to shiny things
Old 08-02-08, 04:57 AM   #9
21QUEST
21QUEST's Avatar
Thanks Northy and Andy for the clarification .
Billy,
Drag, GMS, PMs sent. Cheers all.
Ben
Old 11-02-08, 12:12 AM   #10
21QUEST
21QUEST's Avatar
A bit of update / information.
A couple of the arms had bolts with them and I noticed the bolts were waisted(think that's the correct term) and so decided to try if using them would work...saving having to widen holes(presumme that's what Northy and Andy meant.
Of to SV outside to try. Hmm, find out the end on the Ally ones that bolts onto the swinging arm was not wide enough....huh!!. Definitely would need to be wider--about a mm side......dunno why really but could be, certain years were narrower as the are two different bolts listed on the parts fiche.....so anyone lookign to do same bear that in mind.
Took them to a local engineering firm who milled off the required amount. The bolts(waisted) work so that was good.
Only had two bolts and nuts(locking nut) but after going through my box of bolts found one more...so still two to go lol.
Found a couple more bolts which had to be cut down and also made some top hat sleeves(either end of pic)making the above bolts work in a similar way to the OE bolts.
Top hat sleeves are nothing fancy and could have had a better finish but tool was a bit blunt but works as should
To cap, three people would get the OE blts and nut and two more would get the HT bolts an dthe top hat sleeves......possibly could always buy the OE bolts at a later date but at between £2.50 and £3.00, not sure if it's wort it. If I do find some more bolts, I'll send them along.
So, old one off , new one on...nothing else to do. Sort that lot out meant no posting, so off they go in the morning.
Ben
PS: Remember , you have to use the locking nuts and not just any nut. Four OE type are provided and a the fifth is a Nylock nut.
Rear Brake Caliper Torque Arm andyharding SV Talk, Tuning & Tweaking 8 18-05-08 05:41 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
Rear Brake Caliper Cam_73 SV Talk, Tuning & Tweaking 10 03-02-08 03:36 PM
rear brake caliper torque arm Styler Stuff Wanted 3 04-07-07 06:56 PM
SRAD rear brake reservoir mounting svrash SV Talk, Tuning & Tweaking 1 31-10-06 06:31 PM
