Old 08-02-08, 10:01 PM   #1
steveg
steveg's Avatar
Default When to change brake pads?
Hi all
noticed my rear pads are down to 2mm , what is the minimum recommended before changing , strangley the original front pads are still fine 3.5 mm left after 27 k miles whereas rears only last approx 13 - 15 k I am on 2nd set off rear pads???
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 08-02-08, 10:21 PM   #2
Default Re: when to change brakes pads
If they're wearing quickly then is the caliper serviced? If it's dragging then it'll wear the pads out quicker.
Old 08-02-08, 10:28 PM   #3
steveg
steveg's Avatar
Yep caliper is serviced , just seem to go through rear pads quickly , but do alot of filtering on daily commute ??
What do you recon the min pad thickness is before needs replacing ??
Cheers Steve
AKA Papa Smurf
Old 09-02-08, 08:04 AM   #4
en4rab
I replace the pads when they start making a loud grinding/scraping noise as you brake.
Old 09-02-08, 08:11 AM   #5
flymo
flymo's Avatar
I think waiting for scraping sounds is a bit late.
Advice I got from EBC about their pads was pretty good. They mentioned that the closer the you get to the metal part of the pad then the less effective the insulation from heat. When enough friction material remains then less heat is transferred to the metal backing plate. When this plate begins to heat it retains heat for longer and can heat up everything around it, including the discs causing potential warp.
If you are filtering around town all the time though then I dont think you'll have a problem. Change them when they get close.
Old 09-02-08, 09:22 AM   #6
steveg
steveg's Avatar
Cool will keep a eye on them , as already said when you hear the scraping sound its too late and discs cost alot more than pads
Just read in Haynes I found out for an old bike I used to own and states min thickness is 1mm so should be ok for a while
Cheers Steve
AKA Papa Smurf
Old 09-02-08, 03:17 PM   #7
One thing to remember though; replacing the pads a bit before it's entirely necessary is far cheaper than leaving it too late and having to get a new disc too.
Old 29-09-08, 11:48 AM   #8
dyzio
dyzio's Avatar
Damn! Same thing here!
Bike is on 28k, I was servicing the front callipers, fitting new pads and hoses. Out of geek curiosity, I've checked the condition of the rear pads. Although I've changed them about 11k (EBC organic) ago, they urgently need replacing again.
What wonders me is:
- the front ones were low, but still safe to ride. Can OEM pads do 28k? (I assume the previous owner hasn't changed them) I'm no Rossi but I ain't captain slow either...
- one pad is worn visibly more than the other (rear pads)
The front pads have been changed to EBC organic as well now, I hope they will last more than 10k. Never owned a bike before so don't know much about brake wear...
Old 29-09-08, 11:56 AM   #9
Dangerous Dave
+ 1
I eat through rear pads on the 800, best to replace them before it gets to late...
Old 29-09-08, 12:56 PM   #10
dyzio
dyzio's Avatar
I will remember that from last time
Dave,
roughly, how many miles does "eat through" mean?
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
Brake Pads SV-net SV Talk, Tuning & Tweaking 1 03-10-08 11:52 AM
Brake pads Mike2165 SV Talk, Tuning & Tweaking 8 02-11-07 11:02 PM
Help - Brake Pads T0mm0 SV Talk, Tuning & Tweaking 4 24-05-07 09:25 PM
EBC Pro-Lite brake discs and Goodridge GH brake pads r4ce_e3nd For Sale - SV's and SV related items 7 14-04-07 07:37 PM
