Old 10-02-08, 09:50 PM   #1
SV-net
SV-net's Avatar
Default Spark plug change - how?
Do I have to remove the radiator to change the front plug?
K3 650 N
Hornet 600 Blue 2003 - SOLD
Buell XB9SX Blue 2005 - SOLD
Suzuki GSXR600 Alstare 2003 - SOLD
Aprilia Touno 1000 Black 2004 - SOLD
Suzuki SV650 Silver 2003 - Now SOLD Boo Hoo.
SV-net is offline   Reply With Quote
Old 10-02-08, 10:04 PM   #2
leemole
leemole's Avatar
Default Re: Spark Plug Change ??
on my 99reg you just loosen the bolts and remove the horn, then prop the rad forward with a chunk of wood. bit awkward to do but not hard
LET IT GO OVER YA HEAD
JUST SMILE N WAVE !!!!!
HELP I'VE GOT THE SV1000S BUG !
leemole is offline   Reply With Quote
Old 10-02-08, 10:15 PM   #3
John 675
John 675's Avatar
+1
Triumph Daytona 675 with lots of specials
Formally known as Lylej
There is more to life, finding it is the challenge
John 675 is offline   Reply With Quote
Old 10-02-08, 11:38 PM   #4
5hort5
5hort5's Avatar
I have a K3 S and no you don't need to - undo the bottom bolts and swing up and the rad then use the spark plug tool in the tool kit (plus a pair of pliers on the top to start) and it'll come out
5hort5 is offline   Reply With Quote
Old 11-02-08, 03:40 AM   #5
BanannaMan
BanannaMan's Avatar
What others said....remove lower bolts, tilt radiator forward...
and....
This is a must for removing the spark plug without taking the radiator off.
Old 12-02-08, 08:18 PM   #6
dhtmldude
Junior Member
use a fuel rubber hose to pull the plug from the hole once losened.
dhtmldude is offline   Reply With Quote
Old 12-02-08, 11:02 PM   #7
Take the horn off, it gives you loads more room.
SV spannering in West Yorkshire.
Servicing, Modification, Repairs and Suspension Tweaking
Old 12-02-08, 11:05 PM   #8
sv650k4
sv650k4's Avatar
i changed my spark plugs on my injected model and all i done was take the 2 bolts of the rad i did not remove it completely and it worked very well and was very easy 2 do!!
sv650k4 is offline   Reply With Quote
Old 12-02-08, 11:30 PM   #9
SV-net
SV-net's Avatar
Cheers I did it easily just tilting it forward like you all advised. Thanks loads.
Old 13-02-08, 08:42 PM   #10
shifter
shifter's Avatar
I find although you can tilt the rad, I prefer to drop the coolant. That way you get new plugs and new coolant and not so much risk of damaging the rad!
shifter is offline   Reply With Quote
SV650S clunk sound after spark plug change. fuzzfuzz SV Talk, Tuning & Tweaking 2 13-05-12 12:28 PM
Spark plug - what's the gap? tom-k6 Bikes - Talk & Issues 4 24-03-12 08:23 PM
Spark plug as sump plug? Nobbylad SV Talk, Tuning & Tweaking 25 21-02-11 11:45 AM
Spark plug problem! Phaelok Bikes - Talk & Issues 3 11-02-09 09:28 AM
Spark plug change, now misfiring. butterick99 SV Talk, Tuning & Tweaking 18 09-06-08 07:22 AM
Powered by vBulletin® - Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
