Hey All
I recently have had a fault that has appeared twice and then gone away. the symptoms are that after the bike has been run over a distance of say 50-60 miles it starts to loose power, and feels like its not firing on one of the cylinders every few seconds. it was a dry day and had been for the few days previously. at the time this happened i was on an A road doing 70 in 6th gear. then when I pulled over and let the bike rest for a few minutes it was fine for another mile or two and then the problem happend again. i got back into town and the bike would constantly cut out at the lights unless the revs were kept up above 2k rpm. the next day i checked the spark plugs for wear and sooting, checked the HT leads were not nicked or broken, no water had got into them and put them back on tight. i checked the motion of the FI parts and lubed them and the throttle cables. ive not had the problem since, but im worried about it reoccuring again if i got on a longish run anyone have any ideas that they could throw in as to the possible fault? thanks Paul |
Hi Paul, nice to know there's another Beckenham boy here! Your problem sounds like a post I was reading the other day - could be a blocked breather to your petrol tank. As your bike uses fuel it causes a vaccuum that stops the fuel getting to the engine. you could try taking off the fuel cap and cleaning it..... DON'T DROP ANY SCREWS INTO THE TANK!!!!!! They're a b**ger to get back out
Two suggestions.
Carb icing is like that but yours is a pointy? Water or other crap in fuel would do that.Run fuel low,without running out ![]()
hey Sixstring! ill be looking into that hopefully its something nice and simple. good to see more beckenham sv'ers. you near the high st.?
yeah i got a pointy, sorry should have said that.
water in the fuel certainly is a possiblilty, and would explain why it is intermittent. ive gone through the fuel that was in the tank when it happened, and not had the problem since thanks biggles |
its a custom colour metallic grey (taken from a new transit no less!) pretty standard apart from that and the 14" long carbon stubby!
next time i see a black curvy ill give it a toot lol |
When I had this problem on a carbed bike it turned out to be a bit of water in the fuel. Just emptied the carbs and it worked fine after that. So I assume it would be similar on a FI bike.
Intermittent Speedo | kbh | SV Talk, Tuning & Tweaking | 6 | 14-03-09 07:57 AM |
Intermittent overheating SV650S K5 | hutchy | SV Talk, Tuning & Tweaking | 2 | 13-09-08 11:58 AM |
Intermittent speedo-help please | monkey | SV Talk, Tuning & Tweaking | 3 | 16-05-07 12:26 AM |
electrics intermittent fault | Rog | SV Talk, Tuning & Tweaking | 2 | 02-08-06 07:36 PM |
Intermittent indicators | philb | SV Talk, Tuning & Tweaking | 3 | 11-06-05 08:15 PM |
