Old 12-02-08, 10:03 PM   #1
21QUEST
21QUEST's Avatar
Default Complete Radial Front End ----Perfect for curvy
No clip ons mind...only have one and reckon , you'll need two hehe. Bits have come off my bike.
?650(no offers please) delivered(mainland)
Forks- Good condition. Some marks on them but had them checked by a shop after buying and I haven't crashed in them since I've had them on bike. Recent Oil change About 1500 miles---Silkolene RSF Pro 7.5 and 104mm Air gap.
SRAD Front Wheel---Freshly Powder coated(in Gloss black)
Discs-were brand new when I put them on and have only done about 3000 miles
calipers--will come with good set of pads(OE) that have done bagger all miles...as in, almost new. Also comes with the bolts.
After market Mudguard.....Black fibre glass...comes with bolts
Wheel spindle
Cut down Left side wheel Spacer/nut for SRAD wheel
GSXR750 K2 Yokes(Top and Bottom) with bottom yoke stem swapped to an SV one. Bottom yoke will have bearing(OE) on it.
Lock stop moved so it works on curvy....ignition lock still won't work on Curvy, as, it's offset to the right on the GIXER
The above bits will also work on a pointy but would need a Gixer stem put in which I will do, if a pointy owner buys it. Also the lock stop will have to be move back to make it work on a pointy and again, I'll sort that out.
As with stuff from me, I try to make life as easy as possible for all. All you'll need is a set of bars and that's it. No need to rebuild calipers, forks etc. Old one off and new one in
Will be split and put on the 'fencers paradise' on Thursday if no one wants it
Pics to follow Tonight(or tomorrow)
Ben
Nemo me impune lacessit.
Project Front End Complete!! Rich Photos 14 12-05-08 08:37 PM
Front Brake Pads GSXR-Radial calipers 21QUEST For Sale - SV's and SV related items 0 07-04-08 11:58 PM
GSXR Radial front brake master cylinder DanF For Sale - SV's and SV related items 8 16-03-08 11:24 PM
Radial Front Master Cylinder. petevtwin650 SV Talk, Tuning & Tweaking 5 17-11-07 12:16 AM
Swap GSXR forks/radial brakes/radial master cylinder/wheel Teknic SV Talk, Tuning & Tweaking 2 16-03-05 07:19 AM
