Old 13-02-08, 12:54 PM   #1
nomad
Default Cleaning marks off helmet?
I am after some advice on getting some small marks out of a white Arai helmet.
The marks are very small and are probably from not cleaning off bug splatter properly, they seem to be stained in.
Any suggestions would be appreciated.
Old 13-02-08, 02:34 PM   #2
JediGoat
JediGoat's Avatar
Default Re: Cleaning marks off helmet?
Dunno how to get the marks out, but for carbon helmets you can touch up the paint using the small car paint repair pots.
Jo
JediGoat is offline   Reply With Quote
Old 13-02-08, 03:05 PM   #3
nomad
Cheers Jo
I have thought about painting thin coat to see if it would be drawn in and effectively stain the marks white but I would prefer to see if I can draw out the marks first.
Old 13-02-08, 03:15 PM   #4
DanAbnormal
Giggle!
I'd better leave.
Old 13-02-08, 03:21 PM   #5
DanAbnormal
This is too much. I' have to leave...........
How about Muc Off? Works on plastic bodywork so may be good for your lid too?
Old 13-02-08, 03:30 PM   #6
rob13
Muc-off might not be a bad idea, just wipe over with a cloth afterwards.
Another idea might be Jif? (Or CIF). It tends to be less abrasive than it used to be
Old 13-02-08, 03:37 PM   #7
nomad
I know, I know, there just seemed no way to word it without possibility of innuendo.
Jif or Muc-off could be painful might be worth a try on the Arai, cheers.
Old 13-02-08, 03:47 PM   #8
JediGoat
JediGoat's Avatar
I'd say no to using Muc-Off. If the stain has penetrated the top surface (no sniggering at the back) then you are asking the chemical cleaner to do the same, and you can affect the integrity of the lid.
Also, do not use anything from an aerosol can (butane propellant can damage the EPS inside).
Jo
Old 13-02-08, 05:19 PM   #9
Rune
Xerapol maybe? If your helmet is shiny, that is... Just don't polish it too hard though you might leave even bigger marks.
Old 13-02-08, 05:53 PM   #10
the arai i just got should be cleaned with warm soapy water and nothing else according to the shop, anything with alcohol in will make the side pods brittle.
Cleaning your Helmet,(crash). Speedy Idle Banter 18 19-06-06 10:02 PM
Water marks Skip Bikes - Talk & Issues 11 16-05-06 10:27 AM
Marks on the tank Fuzz SV Talk, Tuning & Tweaking 7 04-03-06 03:05 PM
cleaning the inside of a helmet? ben650 Bikes - Talk & Issues 17 05-01-06 03:57 PM
Cleaning Your Helmet (ooer) Jp Bikes - Talk & Issues 9 07-04-05 02:41 PM
