Old 13-02-08, 11:09 PM   #1
hall13uk
Default removal of debris on exhaust .
have left some my textile trousers on my exhaust pipes (the pipe work runs right by my leg on my 748r) anyone know the best way to remove it? with of course min marks left behind.
I would not normally wear textile trousers on my ducati but i was actually buying leathers at the time.
Thanks all
Old 14-02-08, 12:24 PM   #2
Davies
Default Re: removal of debris on exhaust .
You could give WD40 a go, or maybe try Autosol?
Old 14-02-08, 01:46 PM   #3
fizzwheel
fizzwheel's Avatar
I did the same on my GSXR.
Petrol and a green scourer, then autosol got most of it off. I had a few bits left that I chipped away at with a tiny flat blade screwdriver once I had given what was left a good soak in petrol again to soften it up and then used the autosol again to get the scratches out. Came up good as new.
Might want to take it careful if you have an after market exhaust on there it might scratch or mark worse than a standard exhaust pipe does.
Just try the petrol and then autosol trick with a soft cloth first just make sure you're not going to make things worse.
Old 14-02-08, 01:51 PM   #4
FeRoL
Try running it til the zorst is warm as this helps also. I melted part of my cover to the stock can on the SV it wiped right off with kitchen roll while the can was hot!
Old 14-02-08, 09:22 PM   #5
muffles
Originally Posted by hall13uk View Post
748r
I know you were after a 1098 before, what happened with that in the end? I was looking forward to pics
Old 15-02-08, 09:33 PM   #6
hall13uk
ducati uk customer services happend, what can i say. Anyway their loss, I now have a mint 748r 2002 & another flat, with 2 holidays booked. one of which is to holland on the 748r this summer
my bike>> http://i6.photobucket.com/albums/y24...Picture001.jpg
Old 15-02-08, 10:13 PM   #7
In my experience if it melts on, it'll melt off- so when I do manage to cleverly turn some of my boot or other gear into an exhaust coating i just run the bike til it's at full temperature then get a good thick wad of kitchen roll and wipe as much of it off as possible. The paper scorches but as long as you've got a good few layers it's safe.
Old 16-02-08, 11:48 AM   #8
muffles
Looks nice! Sorry to hear about the 1098...
Old 16-02-08, 05:18 PM   #9
I did this
asked advice the same
Fizz told me the petrol trick..
and it worked..
I would run it first to get it hot
then a rag with a bit of petrol on .. take care of course.. and lots of elbow stuff then clean up with wd40 and then autosol.
I will not be held responsible under C.O.S.H.H if anything mixed creates a nuclear effect.!!
Exhaust dent removal natcar Bikes - Talk & Issues 2 12-08-08 05:44 PM
Exhaust removal issue chakraist SV Talk, Tuning & Tweaking 13 07-08-08 09:19 PM
Laguna Exhaust Manifold removal. Stig Idle Banter 5 28-01-08 09:44 PM
Angle Grinder - Exhaust Removal - Will this do the job? MR UKI (1) SV Talk, Tuning & Tweaking 18 02-04-07 08:17 PM
Motorway Debris Beenz Idle Banter 28 09-01-07 05:58 PM
