Old 16-02-08, 04:39 PM   #1
I'm_a_Newbie
Default Throttle Sync Again
Hi All.
In a final DIY attempt to sort out the poor MPG of my K3 SV650S I have today again balanced the throttle vacuums and adjusted the throttle position sensor.
When I had the front head off last summer I attatched some small bore poly pipe to the vacuum nipples. Today I replaced this with purpose made silicon vacuum tube. The poly pipe was end of roll and very thin and floppy.
Again I made up my own manometer with polypipe, 3 in 1 oil and a piece of wood.
Today's attempt showed the rear vacuum to be quite high compared to the front so I adjusted and kept adjusting until they were even. I then adusted the TPS and then rechecked the balances.
All seems well and the bike is running really smooth. I really hope this is going to get me up the 120 miles until the fuel light again. Last couple of tanks has only seen 85!!! If not then all I can do is get it dynoed with a Yoshi box.
Tim.
throttle body sync cost? silent11 SV Talk, Tuning & Tweaking 7 10-10-08 06:07 PM
sync throttle bodies olden mgroin SV Talk, Tuning & Tweaking 5 29-09-08 07:41 PM
Throttle Sync Yet Again I'm_a_Newbie SV Talk, Tuning & Tweaking 6 13-03-08 12:22 AM
DVD out of sync. phil24_7 Idle Banter 7 16-11-07 05:50 PM
Throttle Sync (K3) problem (search done) mattb200 SV Talk, Tuning & Tweaking 4 09-11-07 02:10 PM
