Old 23-02-08, 06:00 PM   #1
Default Odd, very infrequent misfiring issue
Here's a weird one... For about 30 seconds on the way to work and on the way home on friday, I had a loss of power- it felt exactly like it was losing one cylinder, and it also felt and sounded exactly like it was out of fuel, though that doesn't really fit the bill as it takes off again when it stops exactly as usual- so I doubt the float bowls are draining. Definately not a wet plug. I've checked the obvious suspects- kinked fuel line, negative tank pressure, and just on the off chance I've checked the plugs and fuel filters, all look fine. I'm pretty sure it's keeping one cylinder running, and as soon as it stops, it's absolutely fine. No particular conditions to tie the two, and it wasn't carb icing. I doubt it's rust in the tank as the tank is already petsealed. I did have the tank off and the plugs etc out last weekend for a valve clearance check and some other tidying up, but it's done about 200 miles since and only started with this on friday...
Any options I'm missing out on? It might never happen again but it was annoying, so I'm trying to chase it down. Oh, there were no low-power issues, the bike started strongly the next time I started it, and no telltale dancing needles etc. I tried flicking the lights on and off while it was happening in case it was a drain issue but apparently not. I did have a random flat battery last week during a ride but to be honest I'm blaming rider incompetence and excess load for that!
Old 23-02-08, 06:31 PM   #2
ASM-Forever
Default Re: Odd, very infrequent misfiring issue
My bike exhibits those symptoms when it is dangerously hot and it stops you from revving to save the engine.
But then yours is a SV and you live in Scotland, so thats probably not your problem.
Old 23-02-08, 06:43 PM   #3
richwill68
Here's a weird one... I did have a random flat battery last week during a ride but to be honest I'm blaming rider incompetence and excess load for that!
Had same thing a few months back. Stripped and checked EVERYTHING! Even stripped and visually and electrically checked the wiring loom front to back, soldering the crimped multiple connectors along the way. Eventually traced to a naff generator, which fried the reg/rec, which naffed the battery......BTW, all electrical tests I carried out at home came back within normal range. It was only when tested under load at a specialist auto electricians that the faults showed up!!!
An expensive and time consuming month.
Hope this helps.
Old 23-02-08, 09:15 PM   #4
xbox650
Mines a pointy but I had a similar problem and it turned out to be a faulty throttle position sensor . I don't know if the curvey has one of these or not . Hope this helps .
Old 23-02-08, 09:24 PM   #5
Biker Biggles
Biker Biggles's Avatar
Ignition coil or HT lead breaking down under load or when hot?Faulty plug?
Old 24-02-08, 12:43 AM   #6
My SV's been dangerously hot, even in Scotland. Well, OK, I caused a small electrical fire... But you didn't say how it had to get hot
All ideas go into the list of things to check if it keeps happening... Cheers forks.
Old 24-02-08, 10:22 AM   #7
DoubleD
alarm / immobiliser cutting in.
(if you have one)
Old 24-02-08, 03:05 PM   #8
Blue_SV650S
It may have a bit of **** in the bottom of/floating around the float bowl that it will now pick up from time to time in the main jet ...
Old 24-02-08, 03:22 PM   #9
(if you have one)
I do, but I threw it down the garden last year in triumph after taking it out, and I'm not sure where it landed
I'm tempted to just sling a load of carb cleaner in it and see what happens next... Blue's suggestion seems pretty likely, or something like it.
Old 24-02-08, 04:07 PM   #10
Tim in Belgium
Loose coil connection?
Misfiring update donscarecrow SV Talk, Tuning & Tweaking 0 05-09-08 06:45 PM
SV650S K5 Misfiring? Elky SV Talk, Tuning & Tweaking 9 13-05-08 08:05 AM
Misfiring even in the dry! thumper21 SV Talk, Tuning & Tweaking 9 04-03-07 06:14 PM
Odd misfiring problem drumwrecker SV Talk, Tuning & Tweaking 8 31-01-06 05:15 PM
Misfiring brolong22 SV Talk, Tuning & Tweaking 1 01-11-04 11:08 PM
