Old 28-02-08, 11:47 PM   #1
bad-sv650
Default head bearing nut question ?
how tight do you do up the steering head bearing nut?
I've tapped mine so it's just tight, is that ok?
Old 28-02-08, 11:54 PM   #2
Lissa
Just Ballast
Lissa's Avatar
Default Re: head bearing nut question ?????
If you mean the steering stem nut, it's supposed to be torqued up to 65nm on a curvy.
Old 29-02-08, 12:03 AM   #3
bad-sv650
oh, best knock it back to where it was, thought it was abit lose
I'll get it looked at properly soon I's thinks.
Old 29-02-08, 09:10 AM   #4
Berlin
Hmmm, Might be two different things being talked about here. The bearing and the lock nut for the bearing. I'd presume it's the latter that is torqued to 65 Nm. If you tightened the bearing down to that it'd damage the bearing wouldn't it?
Sounds like the bearing is just right when you tightened it till it's "just tight".
Carl
Old 29-02-08, 10:13 AM   #5
flymo
flymo's Avatar
Carl
...three things maybe. You have the first nut, then a washer and a locknut. Then there is the very top steering stem nut that goes above the top yoke. They are all different torques so need to be clear which one.
Old 29-02-08, 10:54 AM   #6
21QUEST
21QUEST's Avatar
He has got a Curvy so which has, one adjuster nut, then top yoke........
Ben
Nemo me impune lacessit.
Old 29-02-08, 11:00 AM   #7
flymo
flymo's Avatar
Ben
I see, no lock nut on a curvy?
Old 29-02-08, 11:18 AM   #8
Yup, only one bearing preload (?) nut and one nut above the top yoke.
Old 29-02-08, 07:42 PM   #9
Yup. For me, the torque setting on that bottom one is "Till the forks stop rattling, then a little bit more, but not so much that the forks are stiff" but that's not an entirely scientific answer
Old 29-02-08, 08:01 PM   #10
Blue_SV650S
Section 6-26 of the (chassis) manual
That is the official way, but I use the same method as Northy
Head Bearing problems pete m Bikes - Talk & Issues 8 28-04-09 11:00 AM
Crash.NET - Brivio, Romagnoli - head-to-head QA. NewsBot News 0 02-02-09 05:50 PM
Crash.NET - Rossi, Lorenzo - head-to-head QA. NewsBot News 0 02-02-09 05:50 PM
Crash.NET - Rossi, Lorenzo - head-to-head QA! NewsBot News 0 02-02-09 02:50 PM
head bearing nuts kcowgergmm SV Talk, Tuning & Tweaking 4 12-08-07 02:07 PM
