Old 04-03-08, 08:12 AM   #1
Ollie_07
Default Louder Noise when engaging first gear
Took my gear selector off on the weekend, removed the bent selector and fitter the new replacement peg.
Put it all back together, started her up and was going to check i could get into each gear, which it did, but there is a lot louder noise and like more momentum pushing me forward when it goes into first, rather than just the 'click' type noise that happened before.....
Am i just worrying about nothing, or could it be cos the bike has not been used for like a month or so now??
Apart from that i quickly rode up the street and got upto 3rd without an issue, and engaging the other gears seems fine too....
P.S also managed to drop the thing in my garage, luckily it used me as a barrier by pushing me into the wall, and the bike taking most of the fall on my knee!! Ouch!!
I think the bike is still ****ed off with me for having the off!!
I did apologise, what more does she want!!
Old 04-03-08, 08:18 AM   #2
Alpinestarhero
Default Re: Louder Noise when engaging first gear
Does it happen all the time? or only when the bike has just been started? At cold, the clutch does drag a little, so when you engage first gear it can kick forward a bit
Is the cluctch properly adjusted?
Matt
Old 04-03-08, 08:22 AM   #3
Ollie_07
Cant comment on all the time as its not been out for a proper run yet(its got no headlights/fairing/indicators/fender fitted at the mo)
I remember it doing it before but just not as violently, if thats the correct word...
Yep, sure is...
Old 04-03-08, 08:31 AM   #4
petevtwin650
I would guess at clutch drag due to the prolonged inactivity and cold.
Hopefully once the oil is fully warmed up it'll be fine.
Old 04-03-08, 08:31 AM   #5
Alpinestarhero
I imagine its just cold oil making the clutch drag when you first start up then; go for a good ride, get it warmed up. You sound find it clunking into first gear normally when the oil is up to temp (prob after 10 minutes)
Matt
Old 04-03-08, 08:33 AM   #6
Ollie_07
Matt
Thanks Pete/Matt, that was the answer i wanted to hear!!!
Cant wait to get back out on her!!!!!
louder exhausts wow SV Talk, Tuning & Tweaking 9 31-07-08 08:18 PM
Louder horn quikstu Bikes - Talk & Issues 12 03-10-07 07:10 PM
does oem can get louder with more mileage ? steveg SV Talk, Tuning & Tweaking 17 02-05-06 09:59 AM
Bike stalls when engaging first gear. SVChick SV Talk, Tuning & Tweaking 10 13-02-06 03:57 PM
which is louder? alison_w Exhausts 5 12-10-04 08:55 AM
