Old 04-03-08, 04:26 PM   #1
Troy
Default Had an off, what to inspect before riding again? (some pics too)
Hi folks,
Technical details: 2001 SV650S, second owner, ~22k miles (yes, I'm a yank! ), non-OEM parts include a K&N air filter, that's it.
A while back on a winter morning, the combination of cold engine and cold tires led me to have a very unexpected transition from rider to pedestrian. A fairly low-speed high-side slammed me and the bike down on the right side pretty hard. Broke some various bits and pieces:
The bracket for the rear pedal and brake, turn signal, front brake plastic thingy from the reservior, fairing, mirror. Oh, and one of these too:
I've replaced the bracket, the plastic front brake piece, the turn signal, and "fixed" the fairing and mirror in truly ghettofabulous fashion with some duct tape and 2 part epoxy... I flushed the brake systems front and rear, new fluid, oil change, bit of a tuneup with new spark plugs and air filter...
It looks like it's ready for the road again. Anything I might be missing? If you slammed your bike down pretty hard, what else would you inspect before taking it back on the road? And please don't say, "Your riding technique." I've already learned a few lessons the hard way.
Any help appreciated!
Sincerely,
-Troy
Old 04-03-08, 04:29 PM   #2
SoulKiss
SoulKiss's Avatar
Default Re: Had an off, what to inspect before riding again? (some pics too)
Originally Posted by Troy View Post
Hi folks,
Sincerely,
-Troy
Better hide that straight brake lever - Chris numbers will be along in a minute wanting it :P
Good to hear you are getting back on the road - did my collar bone just before new years in 2006, got of slightly lighter than yo on the damage stakes.
Someone who can advise better on what to look at will be along in a minute I am sure.
Old 04-03-08, 04:32 PM   #3
Bear
Don't worry mate, us limeys use miles as well...
Just off the top of my head I'd check the frame all over for damage, the forks for bends or twisting, the discs and brakes for damage, and all over for oil, coolant and petrol leaks. I'd also have a look at you wheel alignment. Someone more knowledgable than me will be here shortly to update the list for you...
Old 04-03-08, 04:36 PM   #4
petevtwin650
Hi Troy,
Bad luck chum.
First time I've seen a ginger Curvy.
I would get the forks checked out just in case they got a bit twisted. Should only be a matter of loosening off the yokes and setting them, if they are. Also batteries can suffer, but dunno if the modern sealed ones do.
Old 04-03-08, 04:41 PM   #5
well I can see you didn't squish the motosliders then??
Old 04-03-08, 07:36 PM   #6
joshuasv
Troy, Sorry to hear about the off. Hope the shoulder is getting better! Where about are you in Oregon? As others have said, check you frame for obvious damage. Also the wheel alignment, check to see if you forks have twisted in the yokes, check you head bearings to see if there's any play. Just all around give a good look over, brake lines, any leaks. Hitting the fairing like that did you bump the radiator? I'm probably missing something. Not an expert or anything. Tho one may come on along soon and straighten me out! Cheers!
Old 04-03-08, 09:23 PM   #7
maultin
how rusty is that down pipe?
where do you live, Bonneville salt flats?
Seriously though, sorry to hear about the off. The shoulder looks really painful.
Good luck with the mending of body & bike
Old 04-03-08, 11:58 PM   #8
Troy
Yeah... The fairing protected them from taking any damage!!!
Originally Posted by joshuasv View Post
Where about are you in Oregon? ... Hitting the fairing like that did you bump the radiator?
Hillsboro, about 15 miles west of Portland. http://maps.google.com/maps?f=q&hl=en&q=hillsboro,+or
I checked the radiator pretty closely, it looks like the rubber nubs that the fairing sticks into prevented any tweaking of the radiator itself. Nothing bent there, no leaks.
Originally Posted by maultin View Post
how rusty is that down pipe? where do you live, Bonneville salt flats?
Quiet, you!!! It's just surface rust. I figure if I clean it, it will just expose more metal to get rusted. It's protective layer of rust!
Originally Posted by <Everyone...>
'Check the frame and the forks'
Thanks for the suggestion there. The frame is fine, the fairing and my leg and shoulder did a good job protecting it. Is checking the fork alignment something that would be in my maintenance manual, or something I should definitely take it to the shop for? I'm no stranger to a wrench and have a decent array of tools.
Thanks! err... Cheers!
-Troy
Old 05-03-08, 06:06 AM   #9
joshuasv
I lived in Portland for about nine years. Now I'm in central Oregon. If you have a front stand that supports by the neck you can loosen the yokes to see if the forks have twisted. Make sure you support the front wheel so it dose not drop any. You can then use the string method to check your wheel alignment. A quick search on here for wheel alignment will give you some good results on that method if you are unfamiliar. You can always look for a shop that has a laser alignment tool if all else fails. Cheers!
Old 05-03-08, 07:58 PM   #10
Troy
Ahh, cool. I've got a friend in Terrebonne who I visit whenever I get a chance. I love the dry, clean (if sometimes a bit dusty!) air of central Oregon.
Any ideas how much one of those might run?
Thanks!
-Troy
Red Riding Ch4 dizzyblonde Idle Banter 9 05-03-09 11:04 PM
Riding with no end can Blue_SV650S Bikes - Talk & Issues 19 29-09-08 11:20 AM
riding without a lid on? John 675 Bikes - Talk & Issues 51 28-11-07 01:54 PM
Riding a SV again... Grinch Bikes - Talk & Issues 8 02-03-06 12:46 PM
went riding in w.virginia this weekend.. woo hoo! (pics) Tinkerbell SV Talk, Tuning & Tweaking 10 02-01-70 02:25 PM
