Old 09-03-08, 09:15 PM   #1
RingDing
RingDing's Avatar
Default Caliper cleaning
I stripped and rebuilt my calipers last weekend. Replaced the seals, greased the sliders for the caliper pins etc. However, the LHS caliper still wouldn't 'float' freely on it's pins. Closer investigation showed that the hole in the caliper that one of the rubber bushes was in had corroded so much it had reduced the ID of the hole and it was 'pinching' the pin. I had to remove the rubber bush from the caliper and spend 15 minutes with iron wool cleaning out the corrosion.
The other caliper was fine. In 18 years of maintaining bikes I've never come across this. Thought I'd point it out in case it can help someone else.
http://ridingalongwayslowly.blogspot.co.uk/
3x Honda C110 - phut-phut-phut
KTM Duke 690 - brum-braaaaaaa!!!!!
BSA C25 - brum-braa-braa
RD350LC Ring-ding-phut-clatter-££££££
RingDing is offline   Reply With Quote
Old 09-03-08, 11:52 PM   #2
Robw#70
Default Re: Caliper cleaning
its 10.2mm hole btw, i just run a drill bit through by hand
Old 10-03-08, 07:38 AM   #3
RingDing
RingDing's Avatar
Cheers Rob, that'll be useful for next time.
Old 10-03-08, 01:48 PM   #4
OldBoy
Had exactly the same thing last year.
http://forums.sv650.org/showthread.p...seized+caliper
Old 10-03-08, 02:00 PM   #5
Yeah I've seen the same thing, scraped all the corrosion out then used wire wool to get it back smooth, and put some rubber grease over the boot so it slides in easy and hopefully gets a little protection.
Cleaning, how far do you take it? TheStudent SV Talk, Tuning & Tweaking 11 06-03-09 11:39 AM
Changing pads and caliper cleaning - few q's dyzio SV Talk, Tuning & Tweaking 8 19-08-08 07:39 PM
Cleaning all around the rear wheel / swingarm / rear brake caliper Camel SV Talk, Tuning & Tweaking 12 28-04-08 02:00 PM
cleaning gettin2dizzy Bikes - Talk & Issues 13 21-03-07 02:58 PM
Cleaning? fizzwheel Idle Banter 17 15-02-06 09:17 PM
