Old 10-03-08, 11:50 AM   #1
Jester666
Question Experimentation type thingy!!
So there I was with the forks out spraying them black!!
When I put them back in I decided to drop the yokes down by 12mm.
Good idea or bad idea?
What can I expect?
Any thoughts welcome!!
Old 10-03-08, 11:53 AM   #2
Bear
Default Re: Experimentation type thingy!!
Should make the bike slightly less stable, but quicker turning. You may find (not sure cos I think you've changed shock, can't remember springs?) that you're ground clearance may be affected.
Old 10-03-08, 11:54 AM   #3
Jester666
Standard SV rear shock, Progressive front springs and 15w oil, 4 preload rings showing.
Old 10-03-08, 12:02 PM   #4
Alpinestarhero
Might feel some sort of differance...but I doubt not alot, as it'll stil be bouncy on the front. Maybe I'll try the same thing aswell, see what happens
Why dont you go out and ride it and tell us what you find
Old 10-03-08, 12:04 PM   #5
pmapp
pmapp's Avatar
Yup, it'll speed up steering.
Old 10-03-08, 12:07 PM   #6
plowsie
Is ground clearance likely to be affected?
Old 10-03-08, 12:25 PM   #7
Dangerous Dave
10mm is the usual for dropping the forks on SV's, for both curvys and pointys. I know that with 10mm you won't have any ground clearence issues or front tyre rubbing issues.
Old 10-03-08, 01:43 PM   #8
Red Herring
Red Herring's Avatar
Just be careful with stability issues if you haven't got a damper fitted. The first you are likely to find out it is affected is when you need it most, ie: coming out of a bend hard on the gas and you catch a bump, especially if it is a left hander and there is some oncoming traffic! Personally I'd have done 5mm first, tried it, then gone for 10mm.
Old 10-03-08, 01:44 PM   #9
Jester666
Yep! I'll go back to 10mm. I've not had problems yet but I'll go easy until I've readjusted them.
Old 10-03-08, 02:01 PM   #10
S or naked?
Ewan and Thingy DarrenSV650S Idle Banter 8 01-11-08 09:41 PM
A4 for sale type poster thingy hovis Idle Banter 7 16-06-08 11:12 AM
What's the name of that thingy on the swing arm.... Kinvig Bikes - Talk & Issues 11 27-05-08 04:30 PM
Carb balancing – experimentation after theorising Blue_SV650S SV Talk, Tuning & Tweaking 6 18-08-07 07:58 AM
30 bhp thingy??? setanta SV Talk, Tuning & Tweaking 11 20-03-06 11:36 PM
