Old 20-03-08, 10:21 PM   #1
I'm_a_Newbie
Thumbs down Front Grip
2 Mornings in a row I have nearly binned the bike on the same roundabout, I could feel the front starting to slide and the bike about to lay down. By reducing throttle and taking off counter steering I managed to pull the bike up again.
About 1 month ago I changed my rear Z6 for a BT021. I still have a Z6 on the front that has done about 5000 miles, so it is now worn flat on the sides, although there is still about 2mm of tread pattern.
It seems the grip in the front does not match that or the rear. (I am really impressed with the grip from BT021).
As the front wears on the sides the contact patch must get bigger so I would have thought grip would have increased.
Either a Z6 front and BT021 rear is not a good combo or my Z6 is shagged!
What do you think? Bad tyre match or shagged tyre?
Thanks
Tim.
Old 20-03-08, 10:25 PM   #2
fizzwheel
fizzwheel's Avatar
Default Re: Front Grip
Sounds like a bit of both possibly. Your front sounds knackered, IMHO get it changed ASAP.
Old 20-03-08, 10:37 PM   #3
Beenz
"About 1 month ago I changed my rear Z6 for a BT021. I still have a Z6 on the front that has done about 5000 miles, so it is now worn flat on the sides, although there is still about 2mm of tread pattern."
Do you mean its worn the middle of the tyre?
Once the profile on any tyre has gone, leaning off the perpendicular the wheel gets more and more nervous untill past the middle portion. 5K from a front can shag the profile, certainly considering the less than perfect road surfaces over the winter. As the bike leans the contact patch goes through a reduced level before it rolls onto the good part of the profile.
It's testemant to your riding that you managed to catch a front end slide, quite often that results in a swift journey to the scene of the crash.
I'd change the front boot to match the rear.
Old 20-03-08, 11:01 PM   #4
I'm_a_Newbie
No I mean on the side of the radius, so instead of being a shape similar to this it starts to look more like as the side of the radius wears away.
Tim.
Old 20-03-08, 11:07 PM   #5
Beenz
No I mean on the side of the radius, so instead of being a shape similar to this it starts to look more like although this as the side of the radius wears away.
Tim.
OK, sorry I should have said 'squared off' my comments are the same though. I'd change the front boot to match the rear. Generally I get two rear tyres for each new front, the bike and riding style may dictate otherwise though.
Old 20-03-08, 11:12 PM   #6
Luckypants
Luckypants's Avatar
My front has gone the same way, leading to some interesting moments. Getting a new pair tomorrow, even though the rear has only 2500 miles on it.
I've gone right off Bridgestones!
Old 20-03-08, 11:23 PM   #7
21QUEST
21QUEST's Avatar
I doubt it's to do with 'bad tyre match' .
I'm of the school of thought that says "neither the front nor the back knows or cares, what's at each end" mind
I cant say if the tyre is significantly worn or not, from your posts but as someone once said to me "if you start asking if it is, it probably is".
Is it okay on other round-abouts? .
Shutting the throttle is probably not what I'll do myself but you got away with it and that's the main thing ... 'good save'
Ben
Nemo me impune lacessit.
Old 20-03-08, 11:28 PM   #8
21QUEST
21QUEST's Avatar
I went of bridgstones years ago. I've never come across a Brand of tyre that cupped(consistently) so badly.
Ben
Old 20-03-08, 11:55 PM   #9
I'm_a_Newbie
Originally Posted by 21QUEST View Post
I'm of the school of thought that says "neither the front nor the back knows or cares, what's at each end" mind Ben
Ok imagine a Sportec Z3 on the rear and a Dunlop D220 on the front, how balanced is that going to be. Or how about D220 rear and Z3 front, that would be a highside waiting to happen!
Is it okay on other round-abouts? . Ben
I don't get to do much riding other than to and from work and this is the only roundabout I use regularly where I get to go most of the way around.
As the roads have been dry for a few days now my speed through corners is picking up again and I am leaning right over.
Ben
I find the engine braking of the SV really good when you need to kill off speed in a bend, as long as you don't close it too quickly or you'll lose traction on the rear as it locks up.
Tim.
Old 21-03-08, 12:39 AM   #10
021s and Roadtecs have pretty similiar round-shouldered profiles, they should work together pretty well- I ran a roadtec front and 020 rear for a long time and that was also fine. That's a terrible mileage for a Roadtec though, 5000 miles? My last one did about 9000 before i took it off to keep it for a spare, it's still the right shape and working well. You should get more than that from a Sportec or similiar never mind a Roadtec. Makes me wonder about tyre pressures...
Grip in Wet? AndyL Bikes - Talk & Issues 33 28-10-08 11:33 PM
Omg Omg GRIP freddifredfred Bikes - Talk & Issues 18 21-01-08 12:00 AM
Grip! - how much? johnnyrod Bikes - Talk & Issues 24 25-09-07 10:28 AM
Need more grip!!!! DarrenSV650S Idle Banter 34 09-12-06 06:52 PM
Help me get a grip! svpilot SV Talk, Tuning & Tweaking 11 02-09-05 08:54 PM
