Old 22-03-08, 08:01 PM   #1
steveg
steveg's Avatar
Question clunking chain noise
Hi all ,
Getting a clunking noise which sounds like its coming form chain .
Have checked chain links and is fine ( chain is only 9k old & scotoilered)
Strange thing is when going slow enough to hear clunking noise , when I pull in clutch it goes , if it was the chain thought it would have been a constant noise ?
Will take a look at front sprocket tomorrow for signs of hooking front sprocket , have not cleaned out the front sprocket area for 9k however this would cause this noise ?
Any other ideas on what to check ?
Cheers Steve
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 23-03-08, 08:02 PM   #2
steveg
steveg's Avatar
Default Re: clunking chain noise
checked front / rear sprockets ok
cleaned out front sprocket
checked wheel alignment ok
checked rear wheel bearings ok
re-checked chain there is one link which is tight to move , not completely seized it has limited movement , chain is scotoilered & apart from this link is in good condition.
have cleaned chain again & lubed however still making clonking noise at low speeds ..
Chain only has 9k on ( normally get 20k +) , however chain is a Iris and after having it fitted heard a lot of poor reviews for iris chains .
Trouble is I'm in Kent Tuesday - Friday , therefore will not be able to get chain replaced .... & I'm hoping to go on the NW3 weekend ... ARGHHHHH
Cheers Steve
AKA Papa Smurf
Old 23-03-08, 10:06 PM   #3
petevtwin650
Oh no Steve,
Deja Vu.
Dunno what to suggest. Hope you make it this time though.
Old 23-03-08, 10:13 PM   #4
steveg
steveg's Avatar
Hi Pete ( & Lissa) ,
I'll give the bike another run tomorrow & over lube / work problem link , hopefully it will free up ...
The chain is in v good condition apart from this link so fingers crossed it will be fine , chain has been scotoilered from new so don't see why only 1 link has knackered itself , I was a bit miffed when garage fitted a Iris chain as I had never heard of it & it did not come with a mileage guarentee which did not bode well...
Cheers Steve
AKA Papa Smurf
Old 23-03-08, 10:39 PM   #5
petevtwin650
Sounds like the garage didn't do the joining link properly. Maybe.
Annoys me when I don't scrimp on bits, then a dealer thinks he's doing me a favour saving a fiver using inferior parts.
It still makes that clunking fork noise. Tony_BLY SV Talk, Tuning & Tweaking 29 01-03-09 10:48 AM
clunking noise under braking nik_nunez SV Talk, Tuning & Tweaking 24 28-08-08 04:24 AM
Clunking noise on GSXR750 rubberduckofdeath Bikes - Talk & Issues 8 06-06-08 05:19 PM
chain is clunking rednorvs SV Talk, Tuning & Tweaking 6 13-11-05 07:08 PM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
