Thames Valley Rideouts and meets for Thames Valleyers and beyond..
Old 24-03-08, 12:50 PM   #1
fat_brstd
Default For the metal heads
I know a couple of you lot are into your metal so thought you might like to hear a couple of tunes from my mates band. Any opinions are welcome. I let you choose how to define it cause its pretty hard to pin down to any one genre. Also they are trying to get a tour together so if anyone knows any promoters that might be interested that would be cool.
Track 1
Track 2
Track 3
Track 4
Track 5
Old 24-03-08, 01:16 PM   #2
hovis
Default Re: For the metal heads
cool name for the band
track 1 ........ seems to be trying too hard, starts off quite heavy, then turns into ska so the screamy vocals dont work.but once the singer stops screaming its not to bad
track 2........ better, i like thrash i also like ska, but i dont think the 2 mix well
track 3 ........ its getting better
track 4 ......... a bit more "mellow" sounds good
track 5 ......... screaming vocals trumtets and keyboards ????
pesonaly i think they need to either scrap the trumpeter or chill out a bit
Old 24-03-08, 03:28 PM   #3
fat_brstd
What keyboards? Its 2 guitars, a bass, drums, a trombone, a trumpet and a sax.
The whole point of it is to try and mix thrash like municipal waste or slayer with the complexities of ska like the blue meanies. Its more metal with a bit of ska chucked in for the sake of it and the arrangements are pretty intense as far as im concerned. Ive never heard anyone come up with anything even remotely close to this other than the flaming tsunamis and there stuff is way more all over the place.
Old 24-03-08, 04:07 PM   #4
ASM-Forever
Ooh i like Track 5.
It is a crazy mash up, but i think it works.
I'm getting a Sublime/Less than Jake vibe.
Old 24-03-08, 05:53 PM   #5
philbut
The start of track one sounds like "train of consiquesnces" by Megadeath..still listening to the rest.
Old 24-03-08, 05:53 PM   #6
philbut
Well I would go mental to it after a few beers, so it gets my approval!
Old 24-03-08, 07:27 PM   #7
Stig
I like all of them. Until they start yelling that is.
Instrumental is class. But they can't sing for toffee.
That's what metal is all about right
Also very annoyed as although I have a 3.5 meg connection, streaming seems to be pathetic and as a consequence have to listen to them in little bursts before it starts to buffer again. Grrrr
Old 24-03-08, 08:26 PM   #8
hovis
keyboards, trombone?
fair enough, but i m not too keen on it, and you did say "Any opinions are welcome"
reminds me of Mr Bungle (a bit)
Old 25-03-08, 03:16 PM   #9
Warthog
Hmm, very interesting. About the only bits of ska I like are NOFX when they go a bit lighter. I would normal listen to heavier stuff than this, but its really not that bad. The thing with cross-over stuff is that if you mix two totally different sounds, you get a song that can't really be listened to in a certain situation. For example, I listen to death metal if I want to have fun and party, and Pink Floyd if I want to relax. I'm not sure I can mix thrash and skanking in one feeling. Totally not crap though at least.
Old 25-03-08, 03:43 PM   #10
philbut
I really like crossover stuff, but then i do have really broad taste in music (some might say cr*p, but I like it!). Both thrash and ska are pretty agressive styles, so they do work together IMO, but then I used to mix Slipknot and DnB together in sets - no really, it works - the more evil the better
chemical metal steveg SV Talk, Tuning & Tweaking 5 19-01-09 11:19 PM
Metal detectors Alpinestarhero Idle Banter 3 17-12-08 09:18 PM
FAO Metal Fans Steve H Idle Banter 67 05-05-07 07:06 PM
Smack heads and crack heads Razor Idle Banter 22 06-10-06 08:00 PM
why? is heavy metal called heavy metal pegasus The Essex Lounge 14 09-06-05 07:26 AM
