Old 27-03-08, 02:01 AM   #1
Grinch
Default Four Breakdowns, one Bike.
Well Helga is not a happy motorcycle.
1st - dead battery, Dave kept me company while Ian came with the jump leads.
2nd - On some road on the way to the SELKENT meet, not sure where as I was following Ian. The speedo and rev counter went mental, plus the lights died just like the start relay had packed up. Check the connection and tightened the ones that seemed loose. Bike jumps OK.
3rd - At the Pied Bull as the battery had not had enough charge on my journey there.
4th - Junction 5 M25 everything goes mental again and I'm plunged into dangerous darkness. Manage to pull over and get recovered back here after a hour plus waitin on the bank.
So busy day tomorrow (today now) me thinks.
Night all.
Old 27-03-08, 02:03 AM   #2
pencil shavings
Default Re: Four Breakdowns, one Bike.
hope its nothing bad!
Old 27-03-08, 02:06 AM   #3
Grinch
Well at the moment I suspect the Starter Relay or water in the loom, as I loose everything. power, lights, dash, ignition. And everything live goes through that relay... so double check it me thinks. Shame the spare is in Portsmouth.
Old 27-03-08, 02:07 AM   #4
pencil shavings
All weather riding was it? :P
Old 27-03-08, 02:10 AM   #5
21QUEST
21QUEST's Avatar
Might be the rectifier .
Ben
Nemo me impune lacessit.
Old 27-03-08, 09:10 AM   #6
Mr Toad
Damn, we followed you until junction 4 where we turned off as you seemed to be going strong
Old 27-03-08, 09:59 AM   #7
Warthog
urgh, what a nightmare.
Old 27-03-08, 11:05 AM   #8
Ben
+1
Old 27-03-08, 11:25 AM   #9
Blue_SV650S
+1
Why would it be the rectifier causing everything to shut down??
Its the starter relay/main fuse box bit or one of the main lead connections for sure!!
Old 27-03-08, 11:28 AM   #10
If it's not getting any charge then it'll conk out, or if its overcharging it could have blown some fuses or damaged the main relay by that?
Worth checking in any case, as if something else has shorted, then it could have done further damage.
